Poll - 2210 top link plate leak
   / Poll - 2210 top link plate leak #11
From what I have heard to this point, the leak has happened in the early production models. My leak (first) started at about 5 hours on the clock. I was not even using the 3PH. My subsequent leaks were all after using an implement. Apparently, there is more to the issue than just the plate, but JD has manufactured a different plate under a different replacement part number. I suspect that most of the units produced more recently have the new plate. Also, there were adjustments required to a "linkage" at each of the fixes I have been through. I have no idea to which "linkage" the adjsutments were done.
JD serial numbers do tell the production age of the tractors. I could not tell you where to find the listing or how to interpret your serial number. Good question for the dealer.
   / Poll - 2210 top link plate leak #12
My 2210 was delivered 11/11/03. I have no leakage but have only 9 hrs. on the tractor and only about 1 hour of that was TPH use. The TPH will get its workout during spring tilling.
I'm curious if they changed the plate on the later models. Perhaps someone with a year old tractor that hasn't been fixed could post a picture? I'd be glad to post one too so we could compare. You know ... you show me yours and I'll show you mine ... /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif
</font><font color="blue" class="small">( jdcook00 asked -- where do they usually leak? )</font>
<font color="green">
See the attached photo previously posted by bigpete. The picture is of the tractor rear.
The leak occurs under the plate you see above the words "TUFF TORQ"
Mike</font>
<font color="blue">(I'm curious if they changed the plate on the later models. Perhaps someone with a year old tractor that hasn't been fixed could post a picture? I'd be glad to post one too so we could compare. ) </font> <font color="green">
I don't have a picture of either but I can tell you from looking at the top link hinge plate on my almost a year old tractor and a new tractor on the dealer's lot, the horizontal piece of steel welded beneath the sides of the hinge is wider and longer on the new tractor.
Mike </font>
   / Poll - 2210 top link plate leak #15
When they fixed my leak they refused to replace the plate because they said there was no contact between tehe 3PT lift ram and the plate. My guess is that any "linkage adjustment" was to try to keep the RAM from contacting the inside of the plate.
   / Poll - 2210 top link plate leak #16
The first top-link plate leak on my 2210 started with about 9 hours on the clock. Deere advised the dealer to just re-seal the plate. Within 5 or so hours of run time the leak returned. No attachments were connected to the 3pt before either leak occurred. On the second repair Deere sent a new beefier plate which the dealer installed with some super gorilla snot (what I call sealer) for the sealant. After the second repair I hung a 400+ pound boxblade on the 3-pt that is attached all the time sans an hour or so per week mowing. At 38 hours no leaks. My 2210 was an early build... delivered to me mid Feb '03.
   / Poll - 2210 top link plate leak #17
I have just settled this morning on a replacement for my 2210. I will post a separate thread discussing the resolution and settlement process but I wanted to complete the timeline of my leak(s) for the purpose of this thread.
-Delivery in Feb. 2003
- Leak #1: First leak within 5 hours of use; no weight on 3PH
-Tractor returned to dealer. Dealer techs identified an unrelated stripped bolt for another bracket; re-seated toplink hinge plate and re-sealed
- Leak #2: Tractor returned to me and again leaked within 10 more hours of use; no weight on 3PH
-Tractor returned to dealership. Techs worked with JD DTAC and engineering. Techs installed a "prototype" reinforced plate
- Leak #3 Tractor returned to me. Plate had minor "weeping" leak within 20 more hours.
-Tractor returned to dealer. "Gorilla Snot" sealant applied to reinstalled prototype toplink plate
Note: All of above took place within 3 months after delivery. 350-pound box blade used as ballast after second leak but well within design limitations and virtuallly no ground engagement.
-No problems or leaks over summer and early fall, approximately 7 months. Summer work primarily mowing and light loader work. Useage increased as fall lawn care and landscaping activities increased. Used tractor for appropriate work with loader removing sidewalk, used box blade for light scraping and leveling, and loader for light digging to modify some landscaping features. Racked up hours to over 100 (I have about 7 acres of land with almost 4 to mow).
-Hurricaine Isablelle--lost several large trees. Used loader for fairly heavy digging to remove stumps and perform clean-up. All work within limts of the machine. Hours up to over 120 now.
-Leak #4 After putting another 15 hours on the clock--after Isabelle--mowing and spreading fertilizer in newly seeded areas, noticed considerable leak from toplink hinge plate. Washed tractor, cleaned and lubed mower deck, called dealer and told him to come pick up the tractor--and keep it. Dateline--First week of November.
A couple of side notes. First, As most of you would have done, I checked out the toplink hinge plate after each and every use. There was clearly no connection between weight or load being carried on the hitch. As was mentioned, there is a level of adjustment for a linkage that may cause some contact of the internal workings of the rockshaft with the toplink hinge plate. While there was never any "warpage" associated with the plate, apparently the plate can flex enough to break the seal. Once the seal is broken, any fluid that splashes onto the inside of the plate has a chance to seep from the contact area.
I received a prototype reinforced plate installed on my tractor that was probably the beginning of JD's the overall solution to a model problem. But the plate is not the entire solution (that's conjecture from all of my conversation with technicians and the field tech supervisor for my region). It makes sense that there is more to this than just replacing a plate. However, since it is a fact that there is a newly designed plate apparently being installed on new build units, it would seem reasonable (to me, not necessarily Deere) that any early build unit receive a redesigned plate as part of the fix for a leak from that area. Again, that's just me....
I also have a theory I would like to share: I do not believe that this is a "pressure leak" issue, but rather, occurs when fluid is "splashed" against the plate and finds a way out of the seal. As such, and in my case, the fluid appeared after work where I might have been bouncing or jouncing around a little bit. This theory is based only in my experiences that after both leak numbers 1 and 2, the dealer told me to keep the fluids up and use the tractor until they could pick it up. They were confident it was just a torque or sealant issue at that time. Anyway, the leak appeared to subside and the reappear after snow plowing which invoved some funny angles and some bouncing around over some packed snow. To finish this thought, a 2210 may have a minor leak that appears to be fine until some rough terrain or work is encountered. This is also supported by the fact that in the first 3 leaks, the shop techs reported no leakage while it was sitting in their shop. Of course they saw the mess when they picked it up, but they could not reproduce it.
The second side note to my saga is that I am happy. Happy with my dealer, his service manager, the shop techs, my salesman, JD Customer Service, and my wife for putting up with me and letting me upgrade as part of my solution. I will expand on that in a separate thread, but I just signed the papers on a similarly equipped 4110 to be delivered within a month (hopefully). I guess I don't have a problem with problem equipment as long as the company makes things right. I was unfortunate to receive one of a few "bad" builds, but I have absolute confidence in the quality and capability of the 2210. I just felt that the nuts and bolts had been torqued and stressed a few too many times on my machine. Nobody ever disagreed with me on that one.
My advice to anybody with this leak is to let your dealer know that you have learned that the symptom is not isolated to your unit. If you think the dealer has not done his work within Deere' technical support syste, call the JD Customer Complaint line at 1-800-537-8233. If you don't actually have a leak, you may not be happy with the response. If you do have a leak, I am sure you will be happy with the courstesy and response. Be patient. It's a huge corporation.
Hopefully the membership committee will extend my membership in "Club 2210," even if it is honorary /forums/images/graemlins/grin.gif
Sorry so long. I thought you guys would like to hear my tale.
   / Poll - 2210 top link plate leak #18
I've had mey 2210 since Early August '03. It sat on the lot waiting to be delivered until we moved in to the house.
No leaks at 30 hrs. Most of those hours were done with the FEL and RT1140 tiller. Not alot of mowing yet, probably 3 times so far, as we have a new lawn.
I'd also like to see pictures of the old and new style top plates if anyone has them. Also, I seem to recall that someone previously posted the Tech note number regarding this. Can you post it again? or link this thread to that post? I mentioned the this to the dealer the other day and he hadn't heard of the problem.
   / Poll - 2210 top link plate leak #19
There have actually been several DTAC case numbers assigned to my tractor, but they are not "solutions" as far as I know. Each case that the technical center opens receives a different number even if it is the same tractor.
I suspect, but do not know for sure, that there is a numbering protocol and publishing method for solutions versus problems. If your dealer cannot find anything in reviewing the "solutions" then perhaps JD has not finalized a fix that will work in all cases. I recall that I learned of a DTAC solution for the very loud noise that my 62C mower deck made. I was able to have my dealer pull the solution and order the part for me at no charge. Dealers are strictly required to provide a problem diagnosis before they can request the parts or warranty service for a specific problem. I intend to ask my service manager whether the solution to my case resulted in a DTAC solutions publications.
   / Poll - 2210 top link plate leak #20
I recieved mine in June 03, approaching 100 hours, no leaks as of yet!!
(INOP) CATERPILLAR 314 EXCAVATOR (A51247)
(INOP) CATERPILLAR...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A55745)
2008 DRAGON 150...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A55745)
2013 ORTEQ ENERGY...
2023 Bobcat T66 (A50120)
2023 Bobcat T66...
2016 CATERPILLAR 950M WHEEL LOADER (A52705)
2016 CATERPILLAR...
