polishing glass
   / polishing glass #1
heehaw
Veteran Member
russellville, arkansas
Kubota M4900, B7510 and RTV
anyone know what i could use to polish the scratches out of the glass on some sunglasses?? the scratches are from the glasses ending up with the glass facing down, and then sitting there in the glove box..
heehaw
   / polishing glass #2
If the lenses are prescription lenses, you should take them back to the optometrist. Trying to polish them yourself could screw up the prescription. Even if the lenses aren't prescription, I'd at least call an optometrist to find out what they might suggest. You could end up scratching them even worse than they are.
If the lenses are a plastic, don't waste your time. You'll spend more time and money trying to salvage the glasses than what they're worth.
   / polishing glass #3
check this out
<A target="_blank" HREF=http://www.scratchpolish.com/glass_restoration.htm>http://www.scratchpolish.com/glass_restoration.htm</A>
   / polishing glass #4
It may not be possible. Most lens are plastic these days but this is not the problem. Many pairs of glasses have a special anti-reflective coating applied to the outside of the lens. This coating probably is what is scrathed and you will end up removing more of it as you try to polish the lens.
If they are plastic underneath it is real tricky to polish them by hand. We polish glass where I work for optical filters, it takes special machines and several compounds to get things right.
Not saying it can't be done, good luck.
Randy
   / polishing glass #5
This won't help you, but after sitting on a pair of $120 sunglasses I bought a clip that holds sunglasses and attaches to your sunvisor. Get it at Sunglass hut or another place like that. It's about 5 bucks, much cheaper than new shades /w3tcompact/icons/smile.gif
2016 CHEVROLET SIVERADO 4X4 PICKUP (A52577)
2016 CHEVROLET...
LMC LOT NUMBER 140 (A53084)
LMC LOT NUMBER 140...
20" Sea Container (A47384)
20" Sea Container...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
2014 CASE 586H FORKLIFT (A52576)
2014 CASE 586H...
