Pole saw promotions
   / Pole saw promotions #11
Shoot just noticed you dont even have the extendable one. Like the ppt 260 280 266 etc
I was thinking about buying the saw head for my pas 280 too.
What powerhead you running?
Info from 2011 when I was researching.
Also 5' section was available for 261 and others. Page Not Found | ECHO USA
I was just curious on the echo number to compare.
PPF 225 7'9" Dry Weight (lb)* 13.9 no bar chain
PPT S 265 8' Dry Weight (lb)* 15.1 "" ""
PPT 265 12' 2" Dry Weight (lb)* 17.4 "" ""
PPT 261 12' 10" Dry Weight (lb)* 16.7 "" ""
PPT 280 13' Dry Weight (lb)* 19.2 '' '' '' ''
ppt ext
   / Pole saw promotions #12
I've got a Jameson b-light pole saw (manual saw). It's pretty amazing - very light and so sharp that it cuts through wood in a snap.
I did a lot of research into power pole saws and while I've no doubt that they've got their place, for many uses a manual saw is sufficient - if not better.
(Note - I did say power saws have their place, but I'd still like people to understand there are alternatives!)
These pole saws come with 6 foot sections of pole - either wood or fiberglass of various wall thickness (I got a pretty light version - plenty strong but very light), with aluminum ferrules (connectors) at the ends, with a hook and saw mounted on a connector you put on the top section. You can use it short (single section) or with as many sections as you need (I've got 4 sections and can cut a limb - with some placement difficulty - that's almost 30' off of the ground, though it's easiest to cut with fewer sections as the poles start getting some bounce the longer they get and you have to learn how to handle it).
If the wood you're cutting is green, the branch comes down before you know it. Cutting through dead oak that's up high is still a chore, but it works. You can also get a pruner that goes on the pole (actuated by rope). Works great if you need to cut something up there.
XYZ, I assume you are asking me this? We didn't get an extendable one because they seemed toooooo long to haul in the back of a UTV. To the best of my knowledge, all Echo power units use the same connector. That is they'll attach to any Echo tool end. We have or had 260 and 280 power units but they all have plenty of power for the chain saw end. These don't seem to need much HP. We get the larger HP units for the string ends that we also use. The pole saw extension part is 4' long.
Hope that helps!
Shoot just noticed you don't even have the extendable one. Like the ppt 260 280 266 etc
ppt ext
We just returned from a weekend of trail clearing with the trusty old saw and other power tools. On the way out to the 1st site, we found a tree across the NFS rd. No problem for a saw on a stick. :) The last 4 are on the trail we maintain when trees came down on it this past week. Note how one can get into these messy crowns and still get them safely cleared.
   / Pole saw promotions #15
I had mine out the other night for a quick timing of a few trees. Love the Combo idea, weed wacked (String trimmer), flipped over to the saw and did the tree trimming and now have the pole hedge trimmer on to do a quick trim of the bushes later this week!
Being able to switch the heads out has been good for our work as well. We hike out and we'll bring different heads along, so we can take care of whatever we find out there.
   / Pole saw promotions #17
The GreenWorks 20302 G-MAX Cordless Pole Saw can handle trimming up to 8 feet because it is extendable. This pole chainsaw has an 8-inch Oregon bar and chain with an automatic oiler to keep the bar and chain lubricated at some points of use. This thing is great for limbing or cutting smaller trees. Pulled it from the box, charged the battery, put chainsaw oil in and went to work.
   / Pole saw promotions #18
I know that most of you are talking commercial quality saws, but on a whim I grabbed the Lynxx from Harbor Freight, it is a 40 volt rechargeable unit with Oregon bar/chain. I bought it thinking it would be toy like in use/function. I was wrong. While I have no doubt that is NOT the saw for a person planning heavy use, it is amazingly serviceable for a person like me with 15 acres and maybe 2 miles of trails plus the tree line along my 3 acre yard. I charged it up and my father and I took it out and thought we would cut a bit until the battery died and decide if it is total junk or not. After 3 hours of passing it back and forth, and sectioning up the limbs on the ground.... it was down to half battery remaining and our arms were DONE! We were both amazed that even on 4" limbs it had no trouble at all. If it lasts a few years with us going out and periodically doing limb trimming and trail touch up work, I got my $140 worth out of it.
So depending on your service life expectations, the HF Lynxx saw may be worth considering. It is far better than what we expected, but service life is unknown. First impression is that we are amazed at how effective it is at the designed task, and the battery will far outlast your arms ability to use a pole saw unless your some freak of nature that can work overhead all day long. I'm 46 and I can not outlast the battery even while passing it to my 69 year old father when I can not take any more.
Rock, In our case, we do indeed use professional tools. We've occasionally gone into the field and spent 10 hours with pole saws, so battery powered might not cut it . Nonetheless, these might work fine for many people and do let us know how the long term use of your HF one is. Thanks for posting!
Arly,,, not thinking of saws what-so-ever. 220" of snow to date A
   / Pole saw promotions #20
The Lynxx works pretty well for the price. But don't fill the oil tank to the top like you do on a saw and then store it upright. I did that and mine leaked oil all over the unit. It's taken some effort to get the oil out of the sliding mechanism so it'll stay in place. There's a max line on the oil tank sight window and I ignored it. I fill it halfway up the window now.
They just came out with a chain saw.
2019 GENIE S-45XC TELESCOPIC BOOM LIFT (A52709)
2019 GENIE S-45XC...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2-COWBOY PUMPS (A58216)
2-COWBOY PUMPS...
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A58214)
2014 FREIGHTLINER...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
