pole barn squareness?
/ pole barn squareness? #121
</font><font color="blue" class="small">( The one that works day in and day out is the water level ... and cheap to!
Leo )</font>
Mine was wrong out of the box. There is a principal known as static tension that effects water levels. They will get you close, but not exactly perfect.
A carpenters level can be checked by turning it end for end to see if the "level" is maintained. If it changes, it needs to be replaced or re calibrated. He is building a pole barn, and given the amount of difficulty that he has had in the past, if he is a 1/4" or for that matter, 1" off, I won't see it from my home and neither will he standing in front of it. I think that this is going to be one of those cases where "close enough is good enough". The worse that can happen is he will create a tourist attraction known as the "Leaning Pole Barn of ??" There are 12 pages and 119 postings.... lets give this guy a break and let him know that it doesn't have to be dead on level in all directions, unless he wants it to be. If that be the case, then he should hire a engineer to assist. Next thing we know, someone is going to suggest a plumb bob to check the uprights.... /forums/images/graemlins/blush.gif
/ pole barn squareness? #122
Junkman; Sounds like an engineer. Seriously tho, mopower, Junkman is right, your definetly close enough. Just for laughs, take you levels, bubble and lasers, and go to an open house of one those $500,000+ places and check out their floors, walls, etc. I think you'll be impressed with how well you've done. /forums/images/graemlins/laugh.gif
/ pole barn squareness? #123
Well said.
I suggested a month or so ago that he was "within tolerances" and wasn't trying to build a watch or clock. Surely he wants it to be done correctly but you can beat yourself to death with details!
/ pole barn squareness? #124
them lasers can drop 1/4 per 100 ft so it aint perfect. like was said i would of already been nailin on to what you got. the mosture content of the wood dependin on time of year will play heck on you if you tryin to be dead on perfect.
well, laser wasnt accurate, ended up using string levels, done..anyways, my posts are 4x6, i am putting some lengths of lumber nailed to the 4x6 posts under the truss supports to aid in supporting the truss supports, think thats called a scab board? anyway, i will be nailing this to the 3 1/2" part of the 4x6 post, a short length of 2x4 would be the same width as the 4x6 post, but would it help any to use a section of 2x6 instead? yes, it would be wider than the post, but maybe help support it more?
/ pole barn squareness? #126
If your barn is onlt 24' wide then a 2x4 is probably fine. Just fill in the gap between the girder (truss support) and top most girt. That should make you 2x4 at least 18" long. Pop about 10-12 nails in there.
/ pole barn squareness? #127
Let's not go there, we'd need another database for TBN /forums/images/graemlins/grin.gif
/ pole barn squareness? #128
Glad you got it done. Hope you got your money back on the rental unit. Thier pretty easy to calibrate but then you shouldn't have to mess with a rental. Then rental place should be checking those things cause you always get some clown turning something they shoudn't going "whats this do?"
na, they didnt even offer my money back, doesnt surprise me though, well, now i need to figure out what size scab board to nail to the 4 inch side of the posts to aid in holding up the truss supports, if i use 2x4, it will match the width of the post and look better, but 2x6 would probably support a little better because it would be wider, it will be wider than the post its being nailed to, but that would hurt anything would it?
/ pole barn squareness? #130
The scab board would be covered by the tin etc.. so you will not see it. In this particular case I'm not sure that a 2x6 will provide much more support vs the 2x4 but certainly would not hurt anything to use a 2x6. I wouldn't go searching for 2x4's if the 2x6 scraps/leftovers are already handy and available.
The scab board holding strength is from the number of pole nails and length of the board running down the pole.
I'm not sure what the length of the scab board should be though.
got the other side truss supports up, eneded up using a string level strung from the side i already had done over to the side i did today, i just hope to god that the string level method is accurate..? I also used 16" 2x6 for scab boards..I guess im ready for some trussues. do you guys say that the string level is accurate?
/ pole barn squareness? #132
</font><font color="blue" class="small">( .............. do you guys say that the string level is accurate? )</font>
Well, that all depends on the brand of string that ya use. Now if ya use that new fangled string that has some of that poly propoline in it, then it might be a tad off. On the other hand, if ya use the good old fashioned cotton string made in the good ole U. S. of A., then you shouldn't have much problem. If ya used that string the the telephone company uses for pullin wires, you know, the string with the wax impregnant inta it, well ya'all is gone have one heck of a lean to that there buillin. Now if ya purchased that there hemp type of string, well ya gotta smoke it a while and then ya'al not care what that there buildin is gonna look like! /forums/images/graemlins/blush.gif
/ pole barn squareness? #133
Just remember - perfect is a _goal_, not something you will actually achieve. /forums/images/graemlins/smile.gif It's ok if you are off a tad, you will have a bit more work fitting & cutting tin & such, but it's normal. Any of the leveling methods work, it's basically the care you took to recheck & recheck what you are doing, things get closer & closer to 'right'. There are log buildings still standing from the pioneers, & they didn't drag laser levels or even 4' builders levels across the prairie....
In short, your building will be fine, whether or not you got it perfect.
I'm learning a lot by following your threads, thanks for starting & sharing this.
--->Paul
it was some kind of masonry string i got from lowes, comes in a roll of 325 feet..
/ pole barn squareness? #135
</font><font color="blue" class="small">( it was some kind of masonry string i got from Lowe's, comes in a roll of 325 feet.. )</font>
I think that you should have gotten carpenters string. I don't know how well the mason's string will work with wood. /forums/images/graemlins/wink.gif Did you check it with a carpenters level or a masons level? It isn't good to mix tools from different trades. /forums/images/graemlins/shocked.gif
2014 CATERPILLAR 938K WHEEL LOADER (A65053)
2014 CATERPILLAR...
Ford 8210 (A60462)
Ford 8210 (A60462)
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
ATS Mini Excavator (A66285)
ATS Mini Excavator...
