Pole barn sliding door adjust Q
   / Pole barn sliding door adjust Q #1
BarryinMN
Platinum Member
Minnesota
JD, Allis-Chalmers, Zetor
Anyone have a tip on how to adjust these overhead track doors: Tightening the nuts on the track roller has no efect... /forums/images/graemlins/mad.gif
Barry
   / Pole barn sliding door adjust Q #2
Hi Barry,
I'm not exactly sure what help you need. If you are trying to adjust the door, the bolts that the door hangs off the wheel assemblies are eccentric . You rotate the bolts to position the door the way you want it, closer or farther from the building and the nuts raise or lower the door up and down for level. There should be a pair of nuts on the bolts to lock them in place when you get the bolts adjusted. They jam together to keep the position of the bolt, you don't "tighten them". Good luck, it’s kind of an iterative process… You may also have to do some adjusting to the track to get the door just the way you want it.
Dave
Aha eccentric I'll try that this next weekend.
The adjustment problem is height - bottom of door on one side drags & I have to lift it to pin lock it to the other.
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A53472)
2021 NEW HOLLAND...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
72" Hydraulic Broom  (A52384)
72" Hydraulic...
2022 Caterpillar 310 Midi Excavator (A51691)
2022 Caterpillar...
6" & 10" I BEAMS UP TO 40' LONG & MISC (A51247)
6" & 10" I BEAMS...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
