Pole Barn Project
   / Pole Barn Project #1
Docsknotinn
Michigan
JD 2210
Well I am just about to start takeing bids for a pole barn. I have absolutely no clue of what to look for. I am thinking a 20 x 40 should do. What would you do differently with yours ? Features ? Things to look for etc. I would like the roof to overhang on one side if possible perhaps 10' like a covered porch to put firwood under. HELP /forums/images/graemlins/crazy.gif Dave
   / Pole Barn Project #2
It will never be to big. Make it as big as you can afford to go.
   / Pole Barn Project #3
That all depends on what you want to do with it. Maybe you could give us a hint /forums/images/graemlins/grin.gif
   / Pole Barn Project #4
My garage is 20x20x10' high... It holds two vehicles, barely, and a work bench along the side. The bumper of a pickup truck is close to the wall and the door. What I'm getting at is make sure you have enough depth for you pickemup truck. If you put a vehicle size door on the short(20') side, you should be OK. If you put the vehicle door on the 40' side, you might be sorry. If I was building a pole barn, I'd go with vehicle doors on both one short and one long side. /forums/images/graemlins/laugh.gif
   / Pole Barn Project
LOL, ok I'll try but you guys all know how it is with a garage ! This is just for my camp. I cant build a cabin for another five years. I need a place to store my tractor and I want to get a bigger one ( Did you hear that SANTA ?) Other than that I need to store a UTV and implements. At the moment I have no intention of putting a truck in it but theres a good thought by MossRoad. The initial prices I am getting are $12 per square ' for the barn plus $3 per sq' for the concrete. This seems very reasonable to me. I was initially thinking 20 x 40 but I might go to 25 x 50 ( MAX ). I am going with a 4/12 pitch for sure and I want a 12' sidewall so I can have a 9-10' garage door on the narrow end. I want 1 window and 1 entry door at the other end. On the opposite side I want the roof and concrete to extend about 10' like a covered porch so I will have a dry place to stack firewood. I want to set up temporary deer camp at one end. As long as I can have a wood stove and room for a couple of cots so I can stop staying in motels and wake up on my own property with my tractor /forums/images/graemlins/grin.gif I will be a happy camper. Dave
   / Pole Barn Project #6
I have a 24 x 46 garage with 14 foot ceilings, a 13 foot door on one end and an 8 footer on the other.
The thing is still way too small /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif
Never enough room /forums/images/graemlins/grin.gif
   / Pole Barn Project
LOL, that's exactly what I mean. But I am wondering if others would have done things differently in a structural sense, different steel, bigger beams etc. Dave
   / Pole Barn Project #8
Dave,
My shop is not a pole barn, but I built it 24X40 with 10' ceilings thinking that would be large enough. At the time my primary use was for woodworking tools and a little mechanicing. Since building it I've purchased a tractor with a few implements and had to add some storage. Now there's a 20' dropshed along the 42' north side and a 24X24 dropshed at each end. I'm currently adding a 26' dropshed along the 42' south side. After I finish that I hope I'll have enough shed space! It's surprising how your requirement for storage space will grow on you.
   / Pole Barn Project #9
Dave - I'd make whatever size you choose in even increments of 4 feet to minimize scrap on materials. The typical garage is 24' wide for instance. Consider putting in a 16' wide garage door as that will make it easier to maneuver in and out. Sounds like you want to wall off a "living area" and insulate that section?
   / Pole Barn Project #10
Dave
I know there never big enough. But if you plan your layout well expanding it in the future will be easier and possible. I belive it is the most critical decision to make. Next to structure reliability
UNUSED FUTURE D45 HYD POST DRIVER (A51248)
UNUSED FUTURE D45...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
King Kutter TG72 Rotary Tiller Tractor Attachment (A51691)
King Kutter TG72...
1998 Genie Z-45/22 Boom Lift (A52384)
1998 Genie Z-45/22...
2008 Ford F-250 Crew Cab Pickup Truck (A51692)
2008 Ford F-250...
