Pole Barn On Existing Slab????
   / Pole Barn On Existing Slab???? #1
optima
I have been reading through the threads and have found a lot of good information, thank you all. I recently purchased some property and it has a 32 x 40 slab already poured. It appears that it is a 6" slab without a footing. I am wondering if I can put up a pole barn on this slab some how. What kind of post anchors would I use. Would the weight of the building crack the slab? Should I pour a footing around the perimeter, or just sink the poles in the ground around the outside of it. I really dont want to bury the poles as I have seen lots of fence post rot off. Any and all suggestions welcome.
   / Pole Barn On Existing Slab???? #2
I had a very simular situation when I bought my house. There was no garage but there was a 30'x24' 6" pad. I checked with building dept. to see if I could just frame a garage up on this pad. They said as long as I had an engineer approve it. I figured it would cost too much to have an engineer come out and not want to take the chance to put his name on it. Because I wanted it attached to the house, I had two options. 1) dig a footer all the way around the pad to build on or 2) put in sonnet tubes and attache the poles to them using post anchores. I went with #2. I made the garage two foot wider and longer (one foot all the way around). This way I could put the tubes in with out messing with the existing pad. After the garage was built I filled in that one foot between walls and pad with concrete. Hope this helps.
Dan
19200 (A50324)
19200 (A50324)
2007 Ford Ranger Pickup Truck (A51692)
2007 Ford Ranger...
23013 (A53421)
23013 (A53421)
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
2025 Epic Electric Golf Cart (A51694)
2025 Epic Electric...
