Pole barn help with a question: Thanks
   / Pole barn help with a question: Thanks #1
rrose002
none
If i square a pole barn using batter boards and it is square for sheathing purposes, roofing ETC..What method do I use to square it up as far as the street view is concerned? I don't want it catty cornered, this is my best explanation as to what I am asking.. Any help will be appreciated..Thank you
   / Pole barn help with a question: Thanks #2
If you want it parallel with a road, then just use the same method of measuring using diagonals. If you want it 100' off the road and the barn is 60' long, then the diagonal would be about 116.6'.
It depends on how far off the road the barn will set as to how difficult this would be to do.
And all that above is IF I understood what the question was.
Good luck.
   / Pole barn help with a question: Thanks #3
I used to do this quite often working on pole barn crew in the '80s. Drive 2 stacks along the side of the road and run a string line on those stakes. Measure off the string line to establish the first wall parallel to the road. This becomes the "fixed" wall when laying out the batter boards and the perpendicular walls are the "adjustable" walls to square it up diagonally.
Thanks guys:thumbsup: I just needed ideas and now I have them, thanks once again:thumbsup:
   / Pole barn help with a question: Thanks #5
A compass will get you pretty darn close. Take a bearing on the road and duplicate that bearing with two stakes anywhere on your property.
Dave.
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
2012 Hitachi PC138 (A47477)
2012 Hitachi PC138...
TEREX RT665 MOBILE CABLE CRANE (A51406)
TEREX RT665 MOBILE...
2015 Ford Transit 150 Cargo Van (A53422)
2015 Ford Transit...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
