Pole Barn heating-what do you use?
   / Pole Barn heating-what do you use? #1
Builder
Super Member
East PA or 750 mi. east of a short man named Dar__
Kubota, AGCO, New Holland LB
I just wanted to start a thread on heating a pole barn. Say it's a typical 60x40 metal sided with concrete floor. Let's say the roof & walls have Tuff-R on them and the floor has 2" under the slab.
I'm thinking of radiant heat-running tubing through the slab to the south facing roof to be preheated in solar panels. The water temp could then be supplemented higher through a simple boiler/water heater with a circulating pump. Maybe use waste oil to fire the heater or electric.
I like the idea of using solar to preheat the water as much as possible (free). A simple shut-off valve could prevent heat in summer.
   / Pole Barn heating-what do you use? #2
on most solar systems you can't just shut valves the collectors will over heat and if its sealed and blow releif valve if there is one if not some thing else will have to give.
tom
Thanks. Yes, I planned on draining the sytem in the summer. Since it'll be filled with anti freeze & water, it's not something you'll want blowing out on the ground.
   / Pole Barn heating-what do you use? #4
We usually cover the collectors in the summer. Too much risk of overheating damage to internal components, even if left dry.
   / Pole Barn heating-what do you use? #7
We cover them with plywood painted white, spaced up by strapping around the edges to keep it off the glass. My father in law puts foam in between plywood & glass. I never have.
I woder if you evacuated the system of most all of the fluid and opened the relief valve, if that wouldn't suffice? Just so you wouldn't have to climb up and cover/uncover the panels?
2006 Toyota Tundra 4X4 Pickup Truck (A53424)
2006 Toyota Tundra...
2025 AGT SDA-140T (A50123)
2025 AGT SDA-140T...
2018 John Deere TX Gator (A50123)
2018 John Deere TX...
2009 40ft High Cube Refrigerated Storage Container (A51691)
2009 40ft High...
2019 John Deere 4052R (A50123)
2019 John Deere...
2018 Chevrolet Tahoe (A51694)
2018 Chevrolet...
