POLE BARN ATTIC WORK
   / POLE BARN ATTIC WORK #1
KB9UDE
Platinum Member
North of Tower Hill, IL
John Deere 4066r John Deere 2025r
Hey guys,
We are getting started working on the electric in our new 40x64 pole barn. I need to run all the overhead electric by walking around in the trusses that are spread 8 feet apart. What size lumber do I need to lay across the trusses so that I can walk the length of the building? I was thinking 2x10 or 2x12. I am 300 plus pounds and dont feel like it breaking and falling almost 20 feet so I am asking for advice.
I will be running EMT conduit up the walls and through the attic areas.
   / POLE BARN ATTIC WORK #2
we make walking boards with 1/4 inch osb with 2x2s in a grid in between and glue the tension is held in cheek buy the bottom piece of osb.....
you can make 16feet from one 1/4 inch sheet of osb and a few 2x4s riped down ..
in my they are stronger and lighter than 2x12 in my opinion we made a set of lawn tractor ramps for a pickup with this idea
o and try it a foot off the ground first....
   / POLE BARN ATTIC WORK #3
Have you considered working off of a rolling scaffolding?
That's how I would do it.
I am not sure I would be comfortable with lumber for planks on an 8" span, for a guy your size.
They would likely work, but all you need is one bad one, or one to move, and your on the way down.
I made a misstep walking trusses, and fell 10' to a concrete floor this year, I don't recommend it.
We dont have concrete poured yet or I would be using scaffolding. I need these boards in place for future use anyway for in the future for after we install the ceiling
   / POLE BARN ATTIC WORK #5
In our attic we just cut up some pieces of OSB up and moved it where we needed it...We're not exactlay "light" either...:ashamed:
That works fine in a 2ft on center stick built building but I am working with 8ft spans between the trusses.
   / POLE BARN ATTIC WORK #7
I'm about 235 lbs, and even a 2x12 at that span would probably be too bouncy for my liking.
Have you considered checking a local tool rental place and see if they have aluminum scaffolding? Like this:
Werner Scaffolding
Actually after you consider buying a lot of 2x12's this might be a good choice for you to purchase for yourself. Maybe find one used, or like I mentioned, rent one if possible. For what you are doing, if you bought one it might actually pay for itself, or you could re-sell it after you are done, etc.
   / POLE BARN ATTIC WORK #8
If scaffolding is out, I would bite the bullet and buy an 18' or 20' step ladder. They are not cheap, but falling 20 feet isn't either. You could recoup a portion (most) of the ladder's cost by selling it on CL when your work is completed.
Just my :2cents:
Steve
   / POLE BARN ATTIC WORK #9
I would opt for the stepladder, too. You will be getting back up there once and awhile and you will put it to use. I have 10 foot ceilings in my barn [about 10.5'] and I have an eight foot and a 12 foot ladder. I think the 12 foot cost $175, and it's a heavy duty fiberglass class A ladder.....worth every penny when you need it. Works great for working outside on the barn and house, too. The ground gets harder as you get older...:) I also have 4 foot centers with just two by four runners to walk on. Also have lights on pull chains and electric duplexes the whole length up there. [ old retired guy ]
   / POLE BARN ATTIC WORK #10
Why use a step ladder here?
You can use an extension ladder.
More stable, easier to move, cheaper, and more useful.
WEATHERFORD MP-10 TRIPLEX MUD PUMP POWERED BY A CATERPILLAR 3412 ENGINE (A50854)
WEATHERFORD MP-10...
2018 Ram 5500 Bucket Truck 4x4 with Versalift VST40 - 45FT Rotating Bucket and Jib Winch (A51039)
2018 Ram 5500...
2021 CATERPILLAR 317 EXCAVATOR (A51242)
2021 CATERPILLAR...
JCB 3CX 15HFCE BACKHOE (A51242)
JCB 3CX 15HFCE...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2020 Chevrolet Express 2500 Cargo Van (A48081)
2020 Chevrolet...
