Polaris Ranger XP700 9 Volt Battery Clip??
   / Polaris Ranger XP700 9 Volt Battery Clip?? #11
It was just a joke !!!!! Nobodys serious ~~~~~~
In reality, it's probobly just a testing post of some sort ~~~~
   / Polaris Ranger XP700 9 Volt Battery Clip?? #12
the same way a 9volt battery can produce 50k volts in a stun gun. the same way a camera flash works it builds up energy then releases it all at one time in a sudden burst. so i think it's very possible to start a utv with it if it's converted the right way.
Gamma said:
How can any of you guys actually think that a little 9-volt transistor sized battery is going to crank over an engine? (Maybe if you had 100 of them connected in parallel) If a little 9-volt battery had enough power to crank an engine over, then there would be thousands of little kids running around with their tongues burned off!!
It's obviously got something to do with the instrument panel area, not the engine starting system.
2013 MACK CHU613 (A58214)
2013 MACK CHU613...
2011 John Deere 5085 70HP Utility Tractor (A55973)
2011 John Deere...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A55302)
2016 Ford F550 4x4...
