Scooby074
Super Member
Firstly Warn is your friend! Some of my friends with cheap china winches had to learn that the hard way
From the pics, "youre not stuck"
Ive been worse.
Upside is it doesnt look like your engine was underwater. Your rear end probably has some mud, but thats not bad. Id still flush and fill all fluids due to the time its been out there.
I think you need to go backwards. Im not sure if those sicks in the picture were put there while trying to get out or not.
Some surface area is needed. Thick plywood or solid wood. Sand ladders. something simiar. Then take a Jackall, put it on what your using for"surface area" and lift the *** end up. Once the wheels are a bit clear. slde something under them, wood, tree.. whatever is handy, to fill the hole. Then try winching or even driving back.
I wouldnt be suprised if you had some stumps or sticks jamming the rear up.
