Polaris Ranger 570 Service
   / Polaris Ranger 570 Service #1
HillStreet
Maine
Kubota B2650HST. Kubota Z125S
Hi Everyone,
Did my first oil change yesterday and I thought it was difficult. I am not a mechanic but have done many oil changes in the past. Maybe it's just the small size of the vehicle, but seems like it was hard to reach the filter and drain plug.
I also looked at the transmission and front gearbox. Looks like Allen wrenches are needed to remove the drain plugs and fill plugs but I don't have that size---- does anybody know the size so I can get one?
It is a pretty cool machine. I had it stored quite a while but I will use it on the property now. Thanks.
   / Polaris Ranger 570 Service #2
I have a Ranger ETX which is mostly the same as a 570, except with a smaller engine. You are correct that all the plugs for oil, transmission fluid, and gearcase oil all require an Allen wrench. I'm not sure the exact size but it is metric - given I didn't have these in my toolkit, I picked up both metric and English in eight piece sets (or maybe it was 10) that fit a 3/8" ratchet from WalMart. This will let you use an extension which will help with access. Fairly cheap - if I recall correctly less than $10 for each set. There are a couple good forums (rangerforums.net and prcforum.com) for Polaris Rangers if you're looking for more info.
Thank you Dale. I have plenty Allen wrenches but none are large enough for the fill plug on the front gearbox. I will get a set.
   / Polaris Ranger 570 Service #4
8mm Allen sockets are what you need. If you have a winch, you will need to unbolt it and slide it out of the way to fill the front diff.
You will need to pull your passengers side running board to grease the prop shaft.
Thanks Will
2012 BMW 328i Coupe (A55853)
2012 BMW 328i...
2017 JOHN DEERE 350G LC EXCAVATOR (A52705)
2017 JOHN DEERE...
UNUSED AGT SSPOC HYD LOG GRABBER (A52706)
UNUSED AGT SSPOC...
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
Ratchet Straps (A55852)
Ratchet Straps...
21012 (A55853)
21012 (A55853)
