Polaris Ranger 570 Service
   / Polaris Ranger 570 Service #1
HillStreet
Veteran Member
Maine
Kubota B2650HST. Kubota Z125S
Hi Everyone,
Did my first oil change yesterday and I thought it was difficult. I am not a mechanic but have done many oil changes in the past. Maybe it's just the small size of the vehicle, but seems like it was hard to reach the filter and drain plug.
I also looked at the transmission and front gearbox. Looks like Allen wrenches are needed to remove the drain plugs and fill plugs but I don't have that size---- does anybody know the size so I can get one?
It is a pretty cool machine. I had it stored quite a while but I will use it on the property now. Thanks.
   / Polaris Ranger 570 Service #2
I have a Ranger ETX which is mostly the same as a 570, except with a smaller engine. You are correct that all the plugs for oil, transmission fluid, and gearcase oil all require an Allen wrench. I'm not sure the exact size but it is metric - given I didn't have these in my toolkit, I picked up both metric and English in eight piece sets (or maybe it was 10) that fit a 3/8" ratchet from WalMart. This will let you use an extension which will help with access. Fairly cheap - if I recall correctly less than $10 for each set. There are a couple good forums (rangerforums.net and prcforum.com) for Polaris Rangers if you're looking for more info.
Thank you Dale. I have plenty Allen wrenches but none are large enough for the fill plug on the front gearbox. I will get a set.
   / Polaris Ranger 570 Service #4
8mm Allen sockets are what you need. If you have a winch, you will need to unbolt it and slide it out of the way to fill the front diff.
You will need to pull your passengers side running board to grease the prop shaft.
Thanks Will
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
City of Tampa (1709) VIN: 1FTYR10U67PA38092,**Title MUST be transferred into buyer's name INCLUDING (A51692)
City of Tampa...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
Case IH 7120 Combine (A50514)
Case IH 7120...
John Deere 7200 Max Emerge II 16 Row Corn Planter (A52349)
John Deere 7200...
