Poison ivy
/ Poison ivy #1
Soapandbacon
Cleveland, Ohio
Kubota BX25D
I've had enough of poison ivy, oak , sumac ... Until I get a few goats around here , has anyone been successful in eradicating these plants from your property ? If so how? And what are the side effects ? Thanks
/ Poison ivy #2
I've beat back the poison ivy with relentless use of Roundup. There will be collateral damage, but it's worth it. Be relentless.
/ Poison ivy #3
/ Poison ivy #4
make up some saltwater and dump it on the poison ivy- kills the plant.
/ Poison ivy #5
/ Poison ivy #6
I use a mix of round up,generic, brush &weed killer and 2-4-d,it even kills the dirt for 3or4mos. Make it strong. Double strength.
/ Poison ivy #7
Young poison ivy can be killed with 2,4D. Add a few drops of Dawn dish soap to cut the surface tension of the ivy for a 1 or 2 gallon sprayer. Only the broadleafs are killed with 2,4D and your grasses will continue growing. Air temperatures typically should be under 85 degrees so the 2,4D does not volatize. As the season goes on and the plants get larger, your options get more limited to glyphosate type products that kill everything that is actively growing. Add a few drops of dish soap or a crop oil to any spray you use on poison ivy to help get the chemical to kill it. Good luck.
/ Poison ivy #8
Stuff in the link was a concentrate mixing of 12 tablespoons per gallon.
/ Poison ivy #9
The link says the 32-ounce container will make 5 gallons, so the 12 tablespoons/gallon of water * 0.5 fluid ounces/tablespoon * 5 gallons of water = 30 ounces, close enough.
The recommended application rate of Crossbow (34.4% 2,4-D and 16.5% triclopyr) for poison oak and ivy is 2 fluid ounces per gallon of water (http://www.cdms.net/ldat/ld02H006.pdf.
Crossbow is expensive, +/1 $150 or so for 2.5 gallons (320 ounces), or $0.47/ounce. However, if you have much to spray, Crossbow is a lot less expensive ($4.70/5 gallon mix) than the linked herbicide ($28/5 gallon mix).
Steve
/ Poison ivy #10
Price 41% glyphosphate at Tractor Supply or other farm store. About $30/gallon or $50/2.5 gallon.
/ Poison ivy #12
Poison ivy and oak don't seem to be able to with stand regular mowing. If all your property is lawn, it probably won't be a problem and for someone who is alergic, making it that way, might be worth it. Unfortunately, part of my lot doesn't lend it's self to mowing. I had to cut a pile of the stuff off a ditch bank with hedge clippers yesterday. The good part is that, it seldom makes me break out.
/ Poison ivy #13
Stoypoint would I mix that from TS or apply it straight. I have a rather large patch at the woodline I would like to get rid of, but cost has always stopped me .
/ Poison ivy #15
The labels for 41% glyphosate say to use 2% of the chemical per gallon of water. This equates to 2.67 ounces of 41% glyphosate per gallon of water. So, if you wanted a 5 gallon mixture, you would add 13.33 ounces of the herbicide to the water. The labels also say "For control. Repeat applications may be required to control. Fall treatments must be applied before leaves lose green color."
At $50 per 2.5 gallons, 41% glyphosate costs $0.16/ounce. Thus, a 5-gallon mix would cost $2.08.
Steve
/ Poison ivy #16
I sprayed a fence line with remedy spring of 2012 & it killed the poison ivy/oak & it still hasn't come back.
/ Poison ivy #17
Goats wont kill ivy!!!-- they will kill all your good trees and shrubs!!---trust me!!! thanks; sonny580
/ Poison ivy #19
My experience is also that roundup won't kill it right away, you have to spary it several times.
/ Poison ivy #20
Steve
Sweet, sounds like that is the way to go and much cheaper than the roundup.
2018 Ford Focus (A61574)
2018 Ford Focus...
Club Car Carryall 6 Medical Utility Cart (A64553)
Club Car Carryall...
2020 Ford Explorer AWD SUV (A64557)
2020 Ford Explorer...
Land Pride RB3584 3-Pt Blade (A66408)
Land Pride RB3584...
(16) Kinze 60 Cell Bean Plates (A65640)
(16) Kinze 60 Cell...
RIDGID AIR COMPRESSOR (A65643)
RIDGID AIR...
