poison ivy
/ poison ivy #21
I tryed the hydrocortisone cream but the PI just keep iching. I am trying not to itch, but you know how it is. I did pick up some techu today, and things are feeling a LITTLE better. Also got some stuff that is from the same Co. a clear gell, and that helped. Looks like I just have a few more days to go./w3tcompact/icons/frown.gif
/ poison ivy #22
find a neighbor with llamas. They love it. My 2 boys ate a 100ft fence covered in the stuff in just a few days.
/ poison ivy #23
llamas huh? Well, I never thought of that./w3tcompact/icons/smile.gif
/ poison ivy #24
poison ivy is like candy to llama's.
/ poison ivy #25
FWIW, Paul, here's a link to Zanfel's website directory of pharmacies which carry the product. <A target="_blank" HREF=http://www2.zanfel.com/ep/pharmacy.html>Zanfel map</A>
/ poison ivy #26
I had PI pretty bad a couple of years ago. After several weeks of suffering, using calamine lotion with no results, I tried a product called Iverest. The rashes were gone in a few days. I highly recommend it. Might not be as good as some of the other products mentioned, but I never tried those so I can't compare.
Remember also, you don't have to touch it to get it. The spores in the air can just blow on you.
/ poison ivy #27
I had a bad case of pi last year, and did some research on it. I found that the oil from the plants is what causes the rash. Like someone else stated, if you have touched it, wash very well with soap and water to remove as much of the oil as possible.
Once the excess oil has been removed, itching the rash WILL NOT SPREAD THE RASH. I found this to be true. At least once a day, I'd itch the spot's raw for relief, and it never, ever spread.
It took almost 3 months to completly clear up, and 10-14 days for the initial contraction to subside. This was with the Prednisone prescription too.
/ poison ivy #28
James,
You've received some good advice here. I've had good success using the "woody plant" version of Roundup. As others have said, I'm not sure you can ever completely eradicate it because of the constant intrusion of new seed sources.
On a different note, I'd like to try and dispel an "old wives' tale" that has cropped up again. The reaction to poison ivy is from the oil in the plant. Once this oil has been removed from your person/clothing, it CAN NOT be spread by scratching or the fluid in the blisters. If anyone thinks it can spread from the blisters, I suggest you check any of the following links:
http://www.drgreene.com/21_611.html
http://www.sawyerproducts.com/Bites_Stings/poison.htm
http://poisonivy.aesir.com/fastfacts.html
Others have also mentioned a Poison Ivy Extract pill. I found them available at <A target="_blank" HREF=http://www.homeopathyworks.com/poisonivy.htm>this location</A>. Be forewarned though, that I also found other references that there may be a problem with side effects from some of these types of pills, so use this information at your own risk.
Hoss
/ poison ivy #29
I agree with the guy who was talking about Ivy Dry. You can still find it in some drugstores. I got a good case of poison ivy this spring. The oil got into my watch band (woven nylon) and really infected my wrist and hand before I know what was going on. My left hand and lower arm was all swollen up from it. I found a bottle of Ivy Dry at the local drugstore, and that dried it up in a couple of days.
The other thing that works is Octagon soap. If I have been exposed to poison ivy, I wash my hands and arms with Octogon soap three times to get the oil off. People here in New England swear by it. The problem is that Octogon soap (or Fels Naptha) is getting harder and harder to find. A local store has agreed to stock it, and it flies off the shelves whenever a shipment comes in.
I have been using the heavy duty Roundup to kill it on my property the last few years. I used to use 2-4-D, but I can't seem to find that here in Rhode Island any more.
A lot of people don't realize that over many years, poison ivy can grow into a sizeable bush that sends runners out for a very long distance. In the late 1970's I had poison ivy growing on a stone wall across the street from my house. A friend gave me some heavy duty herbacide that I sprayed (he said it was the same as Agent Orange), and the poison ivy died after turning colors like leaves do in the fall of the year. The herbacide spread thru the root system, and a couple of weeks after that I saw this bush about 20 feet in the woods turning colors. I went into the woods to look at it and found it was a big bush of poison ivy with"limbs" 2 to 3 inches in diameter! After that bush died, that patch of ivy never came back. I told some of the "old timers" about the bush, and they said that they had observed such poison ivy bushes before. They said it takes many years for poison ivy to grow into a bush that big.
/ poison ivy #30
You're right, your skin is affected only on the areas that the oil touches. The difficulty arises when the oil is on other objects, and you touch those objects and re-contaminate your skin. Leather really soaks it up (i.e. workboots, gloves, belt), as do clothing and tools. I've seen cases in the middle of winter because the woodpile has the remains of ivy vines that get you when you stoke the fire. Shredded hardwood bark used as mulch is usually heavily contaminated with ivy vines. It can even get on pets and then transfer to your hands. Soap and water will decontaminate all these items (but may not be practical on mulch or firewood!) Washing well after exposure can really decrease your risk, and cleaning all contaminated objects will decrease delayed exposures. Also, the speed at which the rash develops is dependent on how thick your skin is - that's why it is rarely seen on the palms, and a single exposure can give rashes that pop up over several days (causing the notion that it's spreading).
2017 Case CX145D (A60462)
2017 Case CX145D...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
2001 John Deere 6210 (A60462)
2001 John Deere...
2019 CHEVROLET SILVERADO LD CREW CAB TRUCK (A59823)
2019 CHEVROLET...
Kubota M5-111 (A53317)
2019 Bobcat T870 (A60462)
2019 Bobcat T870...
