Point Gap for a 1974 212 lawn tractor
   / Point Gap for a 1974 212 lawn tractor #1
mputz
Cameron
212 garden tractor
Can anyone point me to the tune-up specs for a 1974 lawn tractor. A manual for changing the points would be very helpful.
Thanks
   / Point Gap for a 1974 212 lawn tractor #2
Kohler engine about 12 HP .020" for points .... look for S and T marks ... go to kohler website for replacement procedure ....
   / Point Gap for a 1974 212 lawn tractor #3
Think it was Kohler engine on my Gravely. It was 0.020".
Ralph
What is an S and T mark?
   / Point Gap for a 1974 212 lawn tractor #5
The S stands for spark, and the T is for TDC. Actually the starting gap on the points is .020 the gap can vary between .016-.024 to actually get the S mark to line up with the exact moment the point open. Best done with a timing light.
   / Point Gap for a 1974 212 lawn tractor #6
If it is a Kohler motor you can go on their website and they have a lot of the manuals on line for download.
Good luck
   / Point Gap for a 1974 212 lawn tractor #7
set at .018 I have set most of the ones I work on at that and run just fine, are the points new or the old ones you are setting?
   / Point Gap for a 1974 212 lawn tractor #8
Even though the spec on the point gap on the Kohler engine on the Gravely, I recall that I had to set it closer (about 0.016") to get the points to close. Determined this with a light to tell when juice was on or off. With a bigger gap, the juice never got turned on to charge the condenser.
On any "pointed" system, try to find an electronic substitute. I had to do this on an Alfa 1300 cc engine. It kept burning the points up because they didn't align properly. I finally put a Hall electronic system on it.
Ralph
   / Point Gap for a 1974 212 lawn tractor #9
We use the 10-20-30 rule. 10 air gap for flywheel, 20 for point gap and 30 for spark plug. And most match packs were .019 to .020 if you could not find anything else.
Eagle 6010 Safety Cabinet (A50325)
Eagle 6010 Safety...
Generac Generator (A51691)
Generac Generator...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
CENTRAL PNEUMATIC  GAS 135 PSI (A52472)
CENTRAL PNEUMATIC...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
