Po Boy Ballast Box
   / Po Boy Ballast Box #1
California
Super Star Member
An hour north of San Francisco
Yanmar YM240 Yanmar YM186D
Actually, a quick n dirty ballast project.
A rented Ditch Witch did a great job of trenching, I dug 150 ft of trench within their three hour ($125) minimum. But then I had all that loose dirt to fill in. All in a tight corridor where attaching an implement would make the little YM186D too long to maneuver.
I lashed two 80 lb wheel weights to the Quick Hitch. This (plus the 80 lb weights already on each rear wheel) was just right to make the loader push like a (tiny) bulldozer. I have two more of these weights, if this hadn't been sufficient.
I recommend this approach - these are easier to store compared to a purpose-built ballast box.
   / Po Boy Ballast Box #3
Very workable solution. :thumbsup:
   / Po Boy Ballast Box #4
Replaceing those old galvanized rusted out pipes in the farm i guess?
   / Po Boy Ballast Box #5
Great idea.......I have an old washing machine tank filled with rocks that I use for ballast. Ran a pipe thru the tank......hooked it up to by 3 pt......works well. I like your resourcefulness!!:thumbsup:
Replacing those old galvanized rusted out pipes in the farm i guess?
Yep! I should go back to the thread where I asked about modern plastic pipe and do a wrapup. We ended up running all 1.25" PVC mains. No more leaks!
I started out thinking about this ballast project based on building something with 3-point pins .... then took a shortcut when I was standing there staring at the weights on hand. pix: Weights already on the tractor, and a pallet of extra weights - four 80's and fifteen 10's.
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
LMC LOT NUMBER 141 (A53084)
LMC LOT NUMBER 141...
2000 POLARIS MAGNUM 325 ATV (A51406)
2000 POLARIS...
2016 CATERPILLAR 306E EXCAVATOR (A51246)
2016 CATERPILLAR...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
FORD COBRA REPLICA RACING CAR (A52576)
FORD COBRA REPLICA...
