Plumbing a 4 in 1 bucket
   / Plumbing a 4 in 1 bucket #1
VTFireftr
Southern Vermont
Kioti CK 30 gear
Hello All,
I've been thinking about changing the bucket on my CK 30 to a 4 in 1.
I have a few questions:
First, is the CK 30 big enough to handle the 4 in 1?
Second, how difficult is it to install the plumbing for the extra hydraulics?
Third, how would I install the additional hydraulics (I have a Kioti FEL on the tractor)?
Fourth, anything else I should know before I make the purchase?
Thanks in advacne for all your help and expertise.
Marc
   / Plumbing a 4 in 1 bucket #2
You can get a lightweight 4n1 from WR Long or ATI that would be approprieate for a CK30. You'll probably need to add a skid steer adapter unless you have a relatively new CK30. My advice would be to look carefully at the weight of the 4n1. You only have a bit more than 1100lbs lift capacity with the standard bucket as is and you will loose more than a pound for every pound that 4n1 weighs over the standard bucket.
Rigging hydraulics can be done just as for a grapple. There are a lot of posts on TBN about hydraulics for grapples and the information is exactly the same for a 4n1. You can use either a rear remote (cheapest if you already have a remote), or you can install either a diverter valve or electrohydraulic valve. The latter two can be purchased as kits from WRLong and will set you back a grand or more.
Bucket (A55973)
Bucket (A55973)
2005 Peterbilt 387 with Wet Kit (A56435)
2005 Peterbilt 387...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
2014 Jeep Grand Cherokee (A56859)
2014 Jeep Grand...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
