"Plugging holes" in stream wall
/ "Plugging holes" in stream wall #1
JohnSr
Maryland
Kubota B2910, GR2100
Looking for some advice for my brother. He has a natural stream that runs near his home. Recently, after much rain, there was tremendous flooding in the area. The water flow has returned to normal but now water is seeping through an embankment that is soaking his driveway.
Other than damming and temporarily redirecting the water to "repair" the area, does anyone know of a simpler method? Would a mixture of fine and coarse sand plug up the leaks?
We would appreciate any advice!
John
/ "Plugging holes" in stream wall #2
I am by no means an expert and I havent stayed at a holiday inn for a while but this needs to be fixed soon. Is there a culvert under the drive? how is the water getting to the drive? how deep is normal compared to flood? I have used RIPWRAP wich is cement in a poly sack that you use like a sand bag to do simular repairs. And I have had to help rip out a 6' culvert and build a 20'.
long bridge when we did not catch a rusted out culvert in time,and hurricane Denis washed it away. If you can fix it right, right now it will save a lot of time and money. can you get some pictures?
/ "Plugging holes" in stream wall #3
What ever you put along the bank will have to withstand erosion, othewise, the next heavy rain will just wash it away.
I've seen sacks of concret with rebar hammered through them laid along the side of streems to be very effective. Just dig down a few feet for the first layer and start stacking them like bricks. Then pound lengths of rebar right through the sacks. In time, they will harden and become a permanent barrier. The paper will rot away on it's own too.
Cheap, simple and effective.
Eddie
Thank you for the replies... I will take some pictures the next time I go up there to help. I believe he has started on re-directing the water already and has dug a temporary trench to divert the water away from the driveway area so it can dry out. Of course we're getting more rain now so it will take even longer. I did find some info on the Bentonite also but I thought the area had to be completely drained to apply. It sounds like that might be a good thing to try.
/ "Plugging holes" in stream wall #6
You could also dig it out and put in a thick layer of clay. Rock will need to be laid over it to keep it from washing out.
IRRIGATION PIPE FITTINGS (A64276)
IRRIGATION PIPE...
1992 Polar 307 SS T/A Insulated Chemical Tanker Trailer (A68183)
1992 Polar 307 SS...
2009 INTERNATIONAL SF647 GARBAGE TRUCK (A66091)
2009 INTERNATIONAL...
CAT 953C Cab (A68134)
213138 (A64276)
213138 (A64276)
1998 KENWORTH W900 TRIAXLE (A67714)
1998 KENWORTH W900...
