nikdfish
Platinum Member
The pond on our 20 acre site has an overflow pipe that (apparently) the beavers plugged up before moving on a year or so back. The level is now about a foot or so too high & ground on the upper side of the pond, which normally would drain into the pond, is getting pretty swampy with the recent rains.
The overflow pipe is 6" PVC in an L configuration, with the inlet being vertical & the outflow behind the dam roughly 8 feet (or so) below the inlet & about 40 feet back. Getting to the inlet is pretty much out of the question for me, considering the distance from the bank, pond edge growth, water depth & bottom conditions ( & my mobility issues). The outlet is reasonably accessible, though not really great footing for me.
I'm trying to figure a workable plan for unplugging the pipe. I'm thinking that if the blockage is from the beavers shoving stuff down the pipe (plus pond weed ,etc.), I might be able to apply pressure from the outlet side & blow it out.
Lowes sells a device for clearing drains that is inserted into a drain, inflates with water pressure to seal the pipe & then lets water pressure build up beyond the device til the blockage is shoved through. I've got a 120v pump from a former goldfish pond that pulls about 150 watts & can generate about 60 lb. of pressure (as memory serves). It has fittings that match water hose connections. I was thinking about running it from a 450 watt 12v inverter, pulling water from the pond to feed it.
Another approach might be to solvent weld on a threaded end & use a screw in plug with a schrader valve installed in it to try air pressure.
Any other suggestions/observations are definitely welcome, as are alternatives if this initial approach doesn't work.
Nick
Nick
