Like Gerard and the others, 4 inches sounds a little small for
any kind of outdoor drainage, but since it came that way and you're talking 200 feet, I guess you'd really like to make that work.
Since it's the size of household drainpipe, I would suggest you try household drain cleaning techniques. If you can't snake it out from the ends, you might get one of those rubber bladder things that attaches to the end of a hose (assuming you can get a hose to one end of the pipe). Can't remember exactly what they're called (plumbers affectionately refer to them as "douche bags", but this is a family-oriented message board so I will
not use that term), but after you attach it to a hose, you shove it as far into the pipe as you can and then turn on the water full blast. The rubber bladder expands and seals itself inside the pipe so all the water pressure
has to go out the other end. The downstream end of the thing has a relatively small aperture, so you get a pretty good "jet" of water.
If necessary, you might consider fashioning your own temporary pressure cap on the pipe. It wouldn't take much to put a cap on the end that you've adapted with some kind of hose fitting. The idea is to use
hydraulic (how appropriate) pressure to get the job done. Even if you get it only partially cleared, you could then use this pressure system to force a "mouse" (something like a tennis ball) through, pulling a line. Once the line is through, you can try some of the methods that Thomas suggested.
If none of that works, it might be time to call Roto-Rooter (do they have those where you are?).
I guess all ponds are different. Mine, for example, has 3 main inlets which are fed from mountain runoff. The combined water flow can be tremendous at certain times of year, so our overflow is a tad larger than yours -- namely,
four 36-inch diameter pipes (see attached). Of course, we only had to route it past the dam, which is about 20 feet at that point. /w3tcompact/icons/wink.gif
