plug Aerator
/ plug Aerator #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
I need some recommendations on a plug aerator. I dont want a $1000 unit but I dont want junk either.
ALso, does the plug work on weight that you put on it or does the 3 pt hitch hold it into the ground.
Its going on a BX2230.
/ plug Aerator #2
Matt,
I went with a Kioti aerator, 4 feet wide, was $735. I believe they are mfg by Midwest
web page
I add 8 or 10 concrete blocks on top, each block is about 4 inches wide. Low gear 4wd. I go in one direction and then the other direction, spring and fall.
I also have Herd M96 seeder for fertilizer and lime.
web page
/ plug Aerator #3
I've though about buying 2 of the 3 ft aerators at Home Depot (the cheapy kind) and rigging them together on a 3PH. I'm just not sure how long they would hold up though, as I'm sure they would not do as well as a heavier unit................
Initial cost would be much cheaper though.......
ron
/ plug Aerator #4
</font><font color="blue" class="small">( ALso, does the plug work on weight that you put on it or does the 3 pt hitch hold it into the ground. )</font>
As a rule, most 3pt hitches do not have down pressure, so you would add weight to the aerator.
Check with sweettractors, a member here who has new and used aerators for sale. Here's one of his pages. Give him a call, he's said to be very good to work with. John
Sweet Farm Equipment
/ plug Aerator #5
Scrounger,
A 3PH normally only lifts and does not apply down pressure. This is the way it is on the BX and most, if not all, subcuts and cuts...
The weight of the implement (or just the weight of the lift arms & hardware) causes the 3PH to lower...
(I see KiotiJohn is quicker on the draw tonight... /forums/images/graemlins/grin.gif )
/ plug Aerator #6
Tom.... how about a picture of the Hurd M-96 spreader. I have a tow behind spreader that I purchased new and cleaned every time I used it and put it away. After 2 years, it is starting to look like a piece of rusty old farm equipment and I can no longer adjust the outlet flow control. It cost me about $750 and is a piece of crap to say the least. The brand is Sirex from Italy.
/ plug Aerator #7
John..... I purchased my Kioti (Midwest) core aerator from Sweet Tractor and it came in a couple of days. Great people to do business with. Never got around to using it because I was late in getting the lawn in last year. I hope to remove it from the pallet this spring and try it out for the first time. I figure that I got a great deal with the price of steel on the rise, I purchased it at the right time..
/ plug Aerator #8
</font><font color="blue" class="small">( John..... I purchased my Kioti (Midwest) core aerator from Sweet Tractor and it came in a couple of days. Great people to do business with. )</font>
I've been looking at his site lately trying to find something to buy just because everyone talks about how good Ken is to deal with. I figured I'd buy something to help support a good dealer, but I haven't seen what I want yet. It'll come though. Let us know when you finally get to use the aerator. I'd like to know how well it does before I buy one. Tiller is next when I get back from vacation in a couple of weeks. John
/ plug Aerator #9
</font><font color="blue" class="small">( Tiller is next when I get back from vacation in a couple of weeks. John )</font>
Going someplace cold???????? /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ plug Aerator #10
</font><font color="blue" class="small">( Going someplace cold???????? )</font>
Oh yeah. Mexico. Supposed to be in the 90s/60s so I'm prepared to shiver my *** off! /forums/images/graemlins/grin.gif John
/ plug Aerator #11
Do a search for "Core aerator" Here on TBN. You will get a lot of information on them.
Here is a link to a picture showing how I added weight to my 60" Midwest. Click Here
/ plug Aerator #13
Junkman,
You may need to make a modification to the 3 pt to get enough height to lift the aerator so the cores do not drag when in the transport position.. Here is what I plan to follow for the modification.
web page
Make sure when you add the concrete blocks you install a 2 x 4 wood block to lock the concrete blocks into place. The tray is not wide enough to add one more block. If you hit a bump, the concrete blocks move, fall down on the plug which is turning, stops it from turning, and tears the heck out of your lawn if you do not notice it quickly, do not ask how I know this. /forums/images/graemlins/blush.gif I also noticed you will have to tighten the plugs on the turning wheel after use as they loosen up. I use a screw driver to remove the dirt from the plugs before putting it away. Good time to take care of any loose plugs and to grease it up before the next use.
/ plug Aerator #16
Junkman,
I have the Herd M96 Spreader also. I like it alot. My neighbor uses it alot also. Have had it now three years.
murph
/ plug Aerator #17
</font><font color="blue" class="small">( We still have 3 at the same $425 price, If anyone needs one. They can now be shipped via UPS in 2 package )</font>
Ken,
I was on your website and I can't find the core Aerator that Junkman purchased for $425. Do you still have them? What's best method to contact you?
/ plug Aerator #18
</font><font color="blue" class="small">( Junkman,
...........Make sure when you add the concrete blocks you install a 2 x 4 wood block to lock the concrete blocks into place. The tray is not wide enough to add one more block. If you hit a bump, the concrete blocks move, fall down on the plug which is turning, stops it from turning, and tears the heck out of your lawn if you do not notice it quickly, do not ask how I know this. /forums/images/graemlins/blush.gif I also noticed you will have to tighten the plugs on the turning wheel after use as they loosen up. I use a screw driver to remove the dirt from the plugs before putting it away. Good time to take care of any loose plugs and to grease it up before the next use.
)</font>
You know that I was going to ask for a picture, so please post one showing the blocks and the wooden block. Thanks Junk.... /forums/images/graemlins/wink.gif
/ plug Aerator
Is the 425 a special on the site they are showing up for 695. What would shipping be to zip 18040. Thanks.
/ plug Aerator #20
</font><font color="blue" class="small">( We still have 3 at the same $425 price, If anyone needs one. They can now be shipped via UPS in 2 package--Ken Sweet )</font>
I think that was for the Herd Seeder , not the aerator.
2022 Deere 325G (A62180)
2022 Deere 325G...
CAESW IH 4230 TRACTOR (A63290)
CAESW IH 4230...
John Deere Front Mount Frame (A62183)
John Deere Front...
LandHonor Gantry Crane (A62183)
LandHonor Gantry...
SDLanch Livestock Shed (A62183)
SDLanch Livestock...
Zero Turn Mower (A59231)
Zero Turn Mower...
