Pls Check Your GC2310 Steering Tie Rod Knuckles for me
   / Pls Check Your GC2310 Steering Tie Rod Knuckles for me #1
exohomestead
Midwest
MH CG2310, White GT205, Cessna 140
Bringing my new (used) GC2310 up to speed.. The boots around the front steering tie rods are shot. One is badly damage and one is simply gone. I put grease in/on the connections, but that is only a temporary fix.
I'm trying to figure out if I need only new rubber boots or need new knuckles and new rubber boots. There is play in the knuckle, unlike the tie rod ends, where there is no play at all.
How much play is in your steering knuckle? None? Some? Lots? Next time you're out on your tractor, can you raise the front wheels and check the play in your tie rod knuckles and let me know?
Any ideas appreciated!
   / Pls Check Your GC2310 Steering Tie Rod Knuckles for me #2
I just replaced mine and there should be no play in the ball and socket end or the tie rod end. If they are the same as the GC2600 there is a new part number for them and they come as one piece now. Best price I found was Jacks Small Engine. No affiliation just great service.
Rich
2018 John Deere 8270R MFWD Tractor (A53342)
2018 John Deere...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
Tires (A50322)
Tires (A50322)
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2023 DONDI DBR/75 S LOT NUMBER 54 (A53084)
2023 DONDI DBR/75...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
