Plows for dumbies.
/ Plows for dumbies. #21
Sounds like you have pretty much lost any topsoil that may have been there. You need to start adding organic matter -- mulch, manure, grass clippings, chips from tree trimmers, etc. Keep mixing it in, keep it moist.
I'd think about planting an annual rye or something similar as a green manure crop first. The deer will eat it and it has a residue that helps build up the soil reasonably well. See if you can get a blend of seeds with some fast germinating stuff mixed in with perennials.
You notice I didn't mention Kudzu. Hope you don't have any in your area.
/ Plows for dumbies. #22
I am going to follow your lead and use the box blade rippers as a chisel plow/sub soiler/tiller. Isn't the purpose to reach down and break up the soil? After a thorough ripping of the soil then roll the box back raise the rippers and use the tail blade to smooth the surface.
/ Plows for dumbies. #23
The only problems with using just the boxblade rippers is that they really only scratch teh surfae adn not dig down deep where you need the ground broken up.
/ Plows for dumbies. #24
You can make several passes with the boxblade to get into the next layer(s). Rip and drag the topsoil to one end. Rip and drag the next layer(s) to the other end. Then come back and and drag dirt from each end in alternating passes. Be sure to add nutrients like the dateacha said. Last run the rippers way down and tilt the box forward and run several passes through to mix it up. Set your position control so as not to drag any dirt when doing this. Your area will come out pretty good this way. My food plots are small so it was easy for me to use the boxblade as an alternative to a plow or subsoiler.
I'd say I got down 4-5 inches in places but the 'soil' was just right in terms of moisture. Not too hard, not too soft.
I'm still trying to decide what to plant and what to fertilize with. Spreading will have to be done with a basic lawn spreader (again, current budget = $0.00) but the plots are small. I'm not expecting miracles.
However, these small plots are in secluded areas surrounded by dense brush and planted pine and the deer traffic is already high. I just need to give them some reason to hang around a while. They will be the only source of 'food' outside of their natural forage, on my property. I'm thinking even a minimal yield in 'crop' will provide a good yield in terms of deer. We'll see. I've still got to scrape together enough money for seed and fertilizer! Could always 'borrow' a little turkey poop from my B-I-L. If I did it at night he might not even notice. /forums/images/graemlins/grin.gif
/ Plows for dumbies. #26
I have had great success spreading grass seed with a whirly bird style hand held spreader. I have done several acres this way. Seems just the ticket for seeding smaller plots.
Got one of those too. My son can run it and I'll push the yard spreader.
/ Plows for dumbies. #29
I plant about 20 acres in a active rock quarry and first I bottom plow where no trees have been for at least 3-4 yrs, then we disk then plant. After bottom plowing let the dirt sit for at least 3 weeks to start decomposing. Where we have had trees we use a chisel plow or culitvator. Look at the SC Market Bulliten for used equipment scattered thru out the state.
Hey, Turkeyman, my property is just up the road from you near Winnsboro. Lots of turkeys! I've killed two good sized toms so far.
/ Plows for dumbies. #31
I used my boxblade last year and planted annual ryegrass with a hand spreader. It came up very nice and was beautiful to look at. I just added irrigation and used a subsoiler to rip up the ryegrass, and will level it out with my boxblade again, then make raised rows and will be planting berries and lavender. Ain't farming fun?
/ Plows for dumbies. #32
The chiesel plow photo posted earlier was probably more along the lines of a spring tooth harrow, which qualifies as a sort of chiesel plow.
If you really want to bust up the hardpan and promote roots going deeper, and more importantly enable moisture to come up, this site
http://www.marketfarm.com/cfms/chisel_plow.cfm
has a good example of a chiesel plow in use.
They say 10 hp per tooth, I think 12 - 14 is better. A nine tooth chiesel will make a 125 hp tractor sweat in hard ground.
2021 Sol Grand Design BK390 Camper (A62613)
2021 Sol Grand...
(7) Trailer Tires (A65640)
(7) Trailer Tires...
Snap-On Zeus Diagnostic Machine (A63689)
Snap-On Zeus...
2017 Subaru Forrester (A62613)
2017 Subaru...
2012 Freightliner M2106 Bucket Truck, Terex Hi-Ranger HR52M, 52FT Platform Height (A63689)
2012 Freightliner...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
