Plows for 790
   / Plows for 790 #1
Chuck-KY
I have a 790 JD and was looking for a small set of plows. Mostly would be breaking foodplots and rarely any fescue or sod . I have found a 2-12" set of JD plows with break away/reset mechanism and not broke up to pieces as is common with old plows for sell, price is $300. I know this is probably really streching the limits for a 790 4WD, but was wondering if anyone had any experience with a setup like this and if this was a fair price for this plow. I have just bought the tractor and am not really up to speed about what will work for size 790. Thanks for any input you guys might throw my way.
Chuck
   / Plows for 790 #2
do you have the 30hp or 28 hp 790? i have the 28 hp and i'm not sure you could pull a 2 bottom w/ it even w/ filled tires and in 4wd. but i guess it would also depend on your soil. i have a 6ft jd 105 disk and it will make my 790 bury itself in heavy soil unless i'm in 4wd, i don't have loaded tires. you could also possibly convert that plow to a 1 bottom if your tractor couldn't pull it. we used to pull a 2pottom jd trailer plow w/ an old jd b and also a jd 50 those were heavy tractors and would def work in the heavier soil. if you can see if you could try it out b4 buying.
   / Plows for 790 #3
I'm not so sure if it's lacking hp or traction. If you had loaded R1s, I think you'd probably be okay with the 27hp. Unloaded R4s probably would spin.
Also, depends a lot on your soil.
   / Plows for 790 #4
My dad has used our 30hp 790 with a one bottom plow in clay soil and at times its about all it will handle.. Im not sure how/whether it would handle a two bottom
Brian
2013 Ford E-250 Super Duty Cargo Van (A48081)
2013 Ford E-250...
2017 Bad Boy Outlaw XP 61in Zero Turn Commercial Mower (A49346)
2017 Bad Boy...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
Caterpillar 48in Forks and Frame Skid Steer Attachment (A49346)
Caterpillar 48in...
Generac 2000 Series Generator Set (A49346)
Generac 2000...
2021 John Deere R4038 Self Propelled Sprayer (A50657)
2021 John Deere...
