plowing
   / plowing #1
gregNH
I have one simple question: is it possible to plow with a tc 45 with turf tires (when the ground isn't to wet)
   / plowing #2
Turfs arent the best.. but then a 45 is a big tractor. it's all about traction. If you can pull the draft and not break traction you will be fine. Soil makeup, and type plow / number and size of bottoms will be the determining factor.
Soundguy
   / plowing #3
4 wheel drive helps a lot, and turf tires can be pretty sticky if the soil is right. Give it a try, you may be surprised!
   / plowing #4
If it spins too much....get a set of chains for the rear tires.
   / plowing
i will plow with a 1 bottom plow , it is in clay , i ve 125 kg front weights total mass is 1850 kg
   / plowing #6
Single bottom? Even if it is a 16.. should do fine.
Soundguy
   / plowing #7
I agree with the others. Single-bottom you'll probably be OK, assuming the soil's not too soupy. I doubt if you'll make much headway with a two-bottom however as even with the industrials, I sometimes do some slipping with my 2-14". As one suggested, chains would help significantly. A little added weight in both front and back, if you don't already have it, would help too.
   / plowing #8
It was easy for my TC29D Hydro 4x4, and R4s to plow with a 2 - 14" plow.
TAKEUCHI TL6R SKID STEER (A51246)
TAKEUCHI TL6R SKID...
Hyster H225E (A47384)
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A52748)
John Deere 6105E...
2012 JACK COUNTY 130BBL VACUUM TRAILER (A52472)
2012 JACK COUNTY...
2012 GOOSENECK TRAILER MFG.,CO, INC TANDEM AXLE MANIFOLD TRAILER (A52472)
2012 GOOSENECK...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
