plowing
   / plowing #1
gregNH
I have one simple question: is it possible to plow with a tc 45 with turf tires (when the ground isn't to wet)
   / plowing #2
Turfs arent the best.. but then a 45 is a big tractor. it's all about traction. If you can pull the draft and not break traction you will be fine. Soil makeup, and type plow / number and size of bottoms will be the determining factor.
Soundguy
   / plowing #3
4 wheel drive helps a lot, and turf tires can be pretty sticky if the soil is right. Give it a try, you may be surprised!
   / plowing #4
If it spins too much....get a set of chains for the rear tires.
   / plowing
i will plow with a 1 bottom plow , it is in clay , i ve 125 kg front weights total mass is 1850 kg
   / plowing #6
Single bottom? Even if it is a 16.. should do fine.
Soundguy
   / plowing #7
I agree with the others. Single-bottom you'll probably be OK, assuming the soil's not too soupy. I doubt if you'll make much headway with a two-bottom however as even with the industrials, I sometimes do some slipping with my 2-14". As one suggested, chains would help significantly. A little added weight in both front and back, if you don't already have it, would help too.
   / plowing #8
It was easy for my TC29D Hydro 4x4, and R4s to plow with a 2 - 14" plow.
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A51572)
2008 Hino 268...
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2012 International 4300 Reefer Truck (A52748)
2012 International...
