Snow Equipment Owning/Operating Plowing your long driveway.
   / Plowing your long driveway. #11
Yep, last winter, here in the central seaboard area, running out of territory to push the snow was a big deal! A blower would be great. Plus, my neck isn't as flexible as it once was, so a plow blade on the front would be nice. Oh, and heated cab, while I'm at it. Let's hope for a mild winter.
   / Plowing your long driveway. #12
Well, my driveway is 2.5 miles ( yep, miles ) It winds up over a mountain and into my farm. I share the first mile up from the bottom with the coal company on the other side of the mountain but last year they shut down and i had to plow the whole 2.5 miles.
I use the 6ft. rear blade whent he snow is light and under about 12-16 inches. One trip down and back is wide enough but i usually make two trips to make the road wide and clear up some room for snow later. It ususally takes about 1 - 1 1/2 hours to plow it completely.
The last mile into my farm is though the woods and there isn't much room on the sides of the road so once I plow it 2-3 times it is time to bust out the blower because there isn't anywhere to put the snow after a while.
Last year we got 22ft. of snow and I did nothing but run the blower. It took quite a while to keep the road open. Especially since the wind just killed us. It was a daily job to keep the road passable. Lucklily wifey has a Subaru Outback and that thing goes as well as my diesel pickup in the snow, maybe even better.
I used my blower so much and machine gunned so much gravel and rocks that now I have to put the rubber paddle extenders on the fan impellers so i can throw snow a good distance again..
   / Plowing your long driveway. #13
Only 600' of asphalt driveway, but lots of snow in northern lower Michigan. We prefer to use our 5-foot front blower to avoid snow piling up on the sides. The blower makes quick work of the driveway and the two-track to our 30x40 storage building. We do have a back blade, but rarely use it for snow.
John
   / Plowing your long driveway. #14
you would think if your plowing that much snow (that banks become a problem) you could rig up a wing plow off side and or 3pt in the rear.
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
2004 Workhorse W22 Motorhome (A53424)
2004 Workhorse W22...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
2014 Ford Fusion SE Sedan (A55853)
2014 Ford Fusion...
Caterpillar 2PD5000 5,000LB Diesel Warehouse Forklift (A53421)
Caterpillar...
2020 CATERPILLAR 239D3 SKID STEER (A52707)
2020 CATERPILLAR...
