Snow Equipment Owning/Operating Plowing with blade or blowing?
   / Plowing with blade or blowing? #21
I prefer to blow the snow.
   / Plowing with blade or blowing? #22
I plowed snow for a lot of years. ... this has put the fun back into snow removal.
   / Plowing with blade or blowing? #24
Nice, all you need now is a front blade, to pull the snow from the garage doors before you blow.
   / Plowing with blade or blowing? #25
There's actually a back drag blade that goes on the rear of the blower, which allows me to get within 18" of the overhead doors. The rest is up to the homeowner. :)
   / Plowing with blade or blowing? #26
the plow is quick for small snowfalls , but eventually you have to blow/ move it back further as the winter progresses ... the blower disperses it over a larger area so you don't have the bank buildup. ... so it depends on "where" you have to put the snow.
my blower mounts on the front and does most of the snow removal ( gotta get around to building the heated cab this year )
   / Plowing with blade or blowing? #27
Around here pushing snow just makes a ridge or edge that performs as a snow fence and makes the drifting back in even worse. It's a snowblower or a snowshoes around here.
   / Plowing with blade or blowing? #28
I use the loader as much as I can. Use the blower to cut the banks back when they start to protrude into the drive. I was using the blower after every snow fall when I first got it but found I was throwing way too much gravel into the yard. If I dig up any gravel with the loader it's mostly piled where the snow is. Easy to rake up in the spring.
   / Plowing with blade or blowing? #29
For me, it really depends on how much snow is predicted. Accumulations less then 6" get plowed with a Gator and Eagle plow. If I need to, I'll use the tractor bucket to move some of the snow...especially at the end of the drive where the township plows it in from the road.
Anything deeper then 6", it's time to break out the 74" rear blower.
It also depends on the time I have to clean up the snow...if before work, I'll use the gator and plow due to the faster clearing (even if I don't get it all), then I'll use the blower when I get home from work to finish the job.
   / Plowing with blade or blowing? #30
Get rid of it once and for all! Blow it to next door or whatever.
You plow and handle it a couple of times.
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
IRanch Dump Hopper (A55851)
IRanch Dump Hopper...
Year: 2007 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2007 Make...
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
2018 WACKER NEUSON RTSC3 ROLLER (A54607)
2018 WACKER NEUSON...
JOHN DEERE 648R LOT NUMBER 105 (A53084)
JOHN DEERE 648R...
