Plowing with a GC-2300
   / Plowing with a GC-2300 #1
Holts Summit Missouri
Massey Ferguson GC-2300
Does anyone else use a plow and if so how big is it and is it a one or two bottom? I was just wondering cause mine pulls one very easy and was wondering if it could handle a two bottom plow?
   / Plowing with a GC-2300 #2
I would think it will pull a 2 bottom. My 10 hp Bolens pulls a 1 bottom. :D
I was recently reading that farmers are trying to get away from turning the ground over. They were saying initially, its great, but doing it often is no good.
   / Plowing with a GC-2300 #3
I wondered that too. We have a 2 furrow Dearborn (sp??) with one furrow flipped up which we are going to try out on our 1523. If all goes well, we will flip the other down, and see how it does with 2 furrows in the ground.
I will post pics when we plow.
Thanks,
   / Plowing with a GC-2300 #4
Thanks,
Ferguson and Dearborn made a plow that had one bottom flipped up and the other one down. It was made to plow back and forth. One bottom rolled the furrow one way and when the bottoms were flipped it it rolled the furrow the same way going in the opposite direction. Is this the plow you have?
   / Plowing with a GC-2300 #5
Interesting, I did not know that. We flipped one firrow up to plow a drainage ditch, worked great.
Thanks,
   / Plowing with a GC-2300 #6
I have the GC2310TLB with Hydraulic plow. This thing works great...so far I have left the backhoe on for the weight, but when I get a box blade I will use that in the winter for back-dragging and for the weight. Plus the quick hitch needed for the plow will take other accessories. Definitely worth the money, I think with the quick hitch setup I paid $1200 for the plow, the 2340 60" blade.
   / Plowing with a GC-2300 #7
He's not talking about a snow plow.
   / Plowing with a GC-2300 #8
They are talking about this.
http://www.tractorbynet.com/forums/...-operating/110444d1221940406-plowing-gc-2300-
Not this.
http://i283.photobucket.com/albums/kk286/lb59/100_2316.jpg
1000 Gallon Poly Leg Tank (A50121)
1000 Gallon Poly...
Hydraulic Lift Platform (A50121)
Hydraulic Lift...
Kinze 600 Grain Cart (A52349)
Kinze 600 Grain...
2004 Sterling Acterra Truck Cab & Chassis S/A (A51692)
2004 Sterling...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2014 Ford F-150...
