Plowing with a B2920
   / Plowing with a B2920 #1
CJBOTA
Salem, Ohio
Kubota B2620 & MX5100
Next spring I am going to need to plow 2 or 3 Acres. I've never done any plowing. On another site I ask for advice about plowing. Someone said they thought the B2920 could handle a two bottom plow with 14" plowshares. Does this sound reasonable? Also, is it possible to just till or is plowing better? What kind of pattern is best to use when plowing or does it matter? Do you start in the center and work freom one side? Sorry these are dumb questions but I am new at this farming stuff. Any othe advice on techniques would be appreciated. Thanks!
CJBOTA
   / Plowing with a B2920 #2
I don't think it will handle two 14's. It may have the power, but it won't have the weight. I think you will have to go with a single 12" or maybe 14". It may pull better with the FEL as added weight, you will have to experiment.
   / Plowing with a B2920 #3
I'm not an expert here, but it seems like you might be able to get away with 2 x 12" or so. The only reason I say this is because we used to pull a 1 x 10 or 12" plow with a little foofoo 2wd JD 316. We pulled it through nice midwestern soil, but still. The 2920 is a heck of a lot more tractor.
I agree with MDM that you would have to experiment with ballasting.
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
EZ-GO Electric Golf Cart (A50860)
EZ-GO Electric...
2015 GMC Sierra 1500 Pickup Truck (A48081)
2015 GMC Sierra...
2014 Freightliner Ambulance (A50323)
2014 Freightliner...
2021 Liebherr L556 (A51039)
2021 Liebherr L556...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
