Snow Attachments Plowing snow with rear blade going forward
   / Plowing snow with rear blade going forward #31
</font><font color="blue" class="small">( ...aside (or maybe not aside) from the obvious, that is you're plowing over the compacted snow of your wheels, how practical is it to plow FORWARD with a rear blade on a steep and sometimes level gravel driveway?
mike )</font>
Mike -- Absolutely! In fact, that's my preferred method of plowing when I use the tractor. Early or late in the season when the ground isn't frozen I reverse the blade and scrape with the convex edge to avoid digging in. Later, like right now at 10F with lows in the minus 20s, the ground is frozen solid and I use the concave edge. I've never had a problem with compaction.
Pete
   / Plowing snow with rear blade going forward #32
</font><font color="blue" class="small">( My rear blade does not adjust out to the side)</font>
If your rear blade is attached to a 3PH, you can adjust it out to the side somewhat..... you're just not thinking outside the box /forums/images/graemlins/grin.gif
   / Plowing snow with rear blade going forward #33
After reading this thread I thought I would try plowing my gravel driveway that has an incline with my rear blade angled to the side and going forward. It worked quite well and was able to do most of the drive with one pass up and one pass down. I did dig up some dirt on the edge of the drive but not enough to bother. I usually use the rear blade facing front and back the tractor up, pushing the snow into many piles. The angled blade going forward pushed most of the snow to the side. I was working with about 8 inches of moist snow.
My walk behind snow blower does a much neater job and gets the snow further away from the driveway and the snow has less tendency to drift back into the driveway on windy days.
Farwell
   / Plowing snow with rear blade going forward #34
When the snow gets really deep or really wet, with an incline, you'll be amazed at how much more you'll be able to do in the down-hill direction, with the blade angled. than when going up-hill. Either way however, works pretty good IMHO. I still plow the first time or so going forward, with the blade angled, but facing back, just so I don't dig in too bad.
2803 (A50460)
2803 (A50460)
72in Rock Bucket Skid Steer Attachment (A50322)
72in Rock Bucket...
2015 INTERNATIONAL 4300 BOX TRUCK (A51222)
2015 INTERNATIONAL...
2019 CATERPILLAR 299D2 SKID STEER (A51242)
2019 CATERPILLAR...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
1995 KOMATSU WA320-1 WHEEL LOADER (A51242)
1995 KOMATSU...
