Plowing pointers
   / Plowing pointers #11
While I have no actual experience plowing myself... my dad used to always tell me that the most important factor was to know when to plow. In order to get the best results, the soil conditions need to be just right (moisture content, etc.) and to know when that is only comes from experience.
   / Plowing pointers
Thanks everybody. To summarize the most common responses - Get it nice and shiny, go faster and angle it.
As for snow versus dirt, we've only seen a very small flurry this year - you could practically count the flakes. When I did this plowing, this past Sunday, it was in the 60s. The temp has been in the teens today and just broke 20 about an hour ago. It's supposed to be almost 70 on Saturday. Southeast VA.
Keith
   / Plowing pointers #13
Very good post.
To the OP, I agree that it looks like you need a little more speed. In your pics, it looks like the soil is being turned part way over, but not all the way. A little more speed, plus following Crowbar's other tips, should get you.
In my experience with moldboarding (which has been a long time ago), you're never going to get a perfectly smooth field. We always ran a moldboard and then later plowed it with a one-way disc or
tandem disc before we ran a grain drill over it.
I break (plow) a few acres of my land every year (between 50 to 100). I agree with the tips given for the most part. More speed will help to flip the dirt over, but if the grass is thick it would help to harrow over it first. This will also help in getting the plow to level.
You may not get it "smooth", but you should get it level. For small areas like a garden spot you can harrow it back level fairly quick, but on larger acreages you would be in trouble with that.
Another tip for you is to watch the top link pin. When you get the plow set correctly, the pin should be loss when plowing. This works on both my 4 and 5 bottom plows, never had to adjust a 2 bottom, but it should be no different.
I have a 5 bottom switch plow now and it's a bit of a different animal.
   / Plowing pointers #14
Make sure your shares arent worn (the point of the plow)
Once you make a few passes get off and check from behind if the plow is level, if not adjust your 3pt.
Here are some pointers.
Preparing Plow for Use:
There are some manuals for old ford/deerborn plows that give similar info.
   / Plowing pointers #15
KT
Near us in SE Wisconsin they have "Plow Days". It is mostly for the old timers and guys with older equipment to get out and play around with their machines. A local farmer volunteers their property and allows people to plow. All sizes of tractors show up, from 15hp up to over 50hp. It is advertised in the papers and people come out to watch.
There are always people there to ask questions and get advice from. I look forward to it each year. Is there anything like that near you.
Jim
   / Plowing pointers #16
KT
Jim
I'm also from WI and there are several antique tractor plow days. Gaining popularity these days is garden tractor plow days, I ususually try to get to one in the spring and one in the fall each year. Not uncommon for 50 or more garden tractors to get together and plow 20-40 acres in a day. Some of the bigger ones have over 100 tractors.
2014 GMC Terrain SUV (A56859)
2014 GMC Terrain...
2011 KENWORTH T370 (A58214)
2011 KENWORTH T370...
2004 TRAVIS BODY & TRAILER DOUBLE ALUMINUM BELLY DUMP COMBO TRAILER (A58214)
2004 TRAVIS BODY &...
231 (A52708)
231 (A52708)
2012 DODGE RAM 5500 FLATBED (A58214)
2012 DODGE RAM...
2022 Diamond T 14' Dump Trailer, VIN: 5FWDS1423NR030358, Tandem Axle, 7 Gage Steel Floor, Power (A59076)
2022 Diamond T 14'...
