Plow
   / Plow #11
Very nicely (and smartly) done. Many folks would forget all about setting the tractor (or the plow) to simulate "level" once in the furrow. Great redo of a classic, to make it useful again.
   / Plow #12
That plow really does well. I somehow pictured a plow as simply flopping the sod over on the green side and leaving a long ribbon of upside down grass. That's almost like a tiller, looks good.
   / Plow #13
Very,very nice. Good job. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Egon /forums/images/graemlins/grin.gif
   / Plow #14
Great job, Milkman. I also found a cheap old plow some months back but figured it was too big, but ground has been too hard anyway. Now, with your success, I'll give it a try when conditions get better. I was lucky that the prior owner pulled it behind a 8N via a modified 2" sq tool bar for the 3PH so, I just have to hook it up and give it a try without mods. Thanks for the inspiration!
Cheers!
   / Plow #15
I tried that with a David Bradley plow, for my sister in law. Her Economy 14 hp pulled it too well, she hit a rock and bent the beam. /forums/images/graemlins/tongue.gif
   / Plow #16
Milkman,
Looks like you did a real nice job on it. Seems to do a nice job of plowing also.
murph
   / Plow
I appreciate all the kudos, just got lucky i guess, the ground where the garden was, broke up really well but the sod where it hadn't been plowed for years came out a lot rougher, partly because it was so dry and partly because sod just clumps together like that.
   / Plow
Homebrew
I had thought about a plow from an old 8N but I think the beam on the front plow sticks out too far forward to hook up to the BX because of the short TPH arms. I have the Pats Easy Change which makes the arms almost 4" longer and I still don't think they would hook up. I don't think there would be very many instances of soil conditions where you could pull the two bottom because of the lack of traction. I really wanted to find two of the Brinley-Hardy garden tractor plows and make a two bottom plow for my TPH, but I came upon this one and it worked out. Let us know how yours works, with pictures of course.
   / Plow #20
Nice job!
Where is chim now? /forums/images/graemlins/smirk.gif
2023 BOBCAT T76R SERIES SKID STEER (A51242)
2023 BOBCAT T76R...
AGT drum mulcher SSFM81 Attachment (A50322)
AGT drum mulcher...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2015 CAT 573c Fellerbuncher Cutter (A48836)
2015 CAT 573c...
