plow work on CK2510
   / plow work on CK2510 #11
I have a CK20S which is the CK2510's cousin. I can tell you for sure the CK2510 with loader, will pull about as hard as an 8N. I had both. The only problem you will have is the 3 point hitch. The lift arms on an 8N stick out much further. You would run into problems with a bottom plow with the cutter arm. The CK2510 also does not have as much clearance to lift on the 3 point hitch. I think the better overall match for the 8N is a CK27 or even a CK30. I wish I had bought my CK20S with R1s. The R4s do not have as much pull in the field; however, they do better on hard dirt and pavement.
   / plow work on CK2510 #12
A set of Pat's couplers will extend the 3 pt about 4 inches, they help with my finishing mower to keep the front mower tires from hitting the tractor tires.
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
2011 Ford F150 Ext. Cab Pickup Truck (A55973)
2011 Ford F150...
2017 Ford F550 Chassis (A55973)
2017 Ford F550...
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
Jeep Metal Tailgate Themed Wall Decoration (A55853)
Jeep Metal...
1997 Generac T/A Towable 175kW Diesel Generator (A56857)
1997 Generac T/A...
