Plow Weights
   / Plow Weights #1
TBAR
Texas
IH2444 & 1949 Farmall Cub
Ok, I have just acquired a disc plow and need to put some weights in the trays.
Does anyone have pictures of their home made disc plow weights that I could look at to get some ideas?
TBAR
   / Plow Weights #2
You won't need pictures of my implement weights as they are rocks. If you can't find any locally, I'd be happy to send you some free, you pay the shipping, no handling charge. /forums/images/graemlins/wink.gif
   / Plow Weights #4
Certainly just big rocks.
Many trays are built to fit a typical building block or 4.....
--->Paul
   / Plow Weights #5
I use old cylinder heads from old car or truck engines seam to fit in weight box good and you can wire them down thru the bolt holes so they don't bounce out on rough ground
   / Plow Weights #6
Now I feel like a dummy. I went to a scrapyard and spent $50.00 on 260 lbs of Universal Gym wieghts. The plates were 20 lbs apiece and had big holes in the middle for posts that I welded on to the implements. I'll bet cylinder heads would have good weight, plenty of holes and be a lot cheaper. Another poster used cut train rails and welded it directly onto his implements (that way you could also have an anvil out in the field if you needed one)
   / Plow Weights #7
I had some old rail road irons and cut them to fit. i then cut me a holes for some 1/2 " bolts and attached them to my disc's. worked very well just looks like a train could go across my disc's.
   / Plow Weights #8
I'll try to post a pic of the disc I made last year. I too needed weight. So I cut a 50 Gallon drum in half...bolted both halves to the frame and now I can fill it wiith whatever I need. So far I have a lot of old brake discs in there. I pla to put gravel in next to make it all "look pretty." Now I need to weld some new (thicker) attachments for the lowere arms...mine are bendin' a wee bit /forums/images/graemlins/mad.gif
Peter
   / Plow Weights #9
Egon, I think we are just old enough to have seen depression inspired equipment. Nowadays folks don't have that advantage. /forums/images/graemlins/wink.gif
   / Plow Weights #10
That may just be true Slamfire. Think you have a couple of years on me.
Talking about old equipment; seen a very light weight brand new single bottom plough that had two wooden handles on it and a place to attach the single or double tree sitting in the back of a PU.
Egon
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
2010 Lincoln MKS Sedan (A50324)
2010 Lincoln MKS...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
