Plow setup?
   / Plow setup? #1
Bill_C
Gallatin TN
Ford 1100
Okay, I read through the other plowing thread and it mentioned setting up the plow. I'm a complete beginner with a plow...This is a single bottom plow the FIL gave me. It's got a sharp disc, then the curved part of the plow (see, I don't even know basic plow terminology). This part is maybe 12 inches high. There's also a steel wheel about 2" wide behind the curved part, looks like this must control the depth the plow will go.
I played with the toplink a little and got the plow to cut about 2 inches deep, enough to lift the sod and roll it over, but that's about it. This is on hard Tennessee ground that's probably never seen a plow. Sometimes it tries to go deeper but it stops the tractor cold (Ford 1100, 2WD, got rear wheel weights but only turf tires).
How do I set up a plow? What's the basic parts of a plow? Do I need to ditch the turf tires and go for ags, plus adding more weight (tires aren't loaded)?
Thanks, as you can tell I ain't no farmer...yet.
   / Plow setup? #2
Well, my Dad loved plowing far too much to ever teach me how to set up the plow, but maybe I can help a little. I would drive the "high" side of the tractor (when viewed as it would be when plowing) up on to something 4"-6" high so you can stand behind the tractor, and see what is going with the plow as it would be in the furrow. Next, I guess I might adjust the plow on it's frame so that the outside of the "furrow" we are creating here is even with the inside of the back tire. I would then make other adjustments as required so that the plow was sitting flat on the ground, and tracking parallel with the tires of the tractor. Then I would set that depth wheel so that it was about 5"-6" above the ground, and give it a try. We can both learn the names for all these parts after we are having some fun using them.......... :D :D
   / Plow setup? #3
search, farmwithjunk has a great thread on how to set one up complete with pics
probably in the implement section.....
   / Plow setup? #4
if you are turning sod and the ground is hard you may not have enough pull to get your plow any deeper. have you tried to make 2 passes, the first one to roll the sod over and the next to turn the soil?
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
2023 BOBCAT E35 R2 SERIES EXCAVATOR (A52705)
2023 BOBCAT E35 R2...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
FREIGHTLINER BUCKET TRUCK (A51406)
FREIGHTLINER...
3 BATTERY CHARGERS (A53843)
3 BATTERY CHARGERS...
