plow on a 1320
   / plow on a 1320 #1
firstblue
I put an all angle plow on my 89 ford 1320. I tried using the bucket curl hydraulics to angle the plow, but plow would only angle to the left and not swing back to the right. I attached directly to the quick connects for the loader. The plow has two single acting cylinders instead of the double acting for the bucket - would this make a differnence? Any ideas?
   / plow on a 1320 #2
Welcome to the forum.
I believe I have the same setup for plow as yours, i.e. Western plow with three one-way rams.
If I throw the 'curl' lever far to the right (brings the quick dump feature into play) then my snowplow will not angle to the right. However, if I just move the lever to the first 'curl dump' position, then the regenerative circuit doesn't come into play and the blade angles perfectly, same as to the left.
I hook up the angle cylinders to the bucket and the one-way ram to the 'lift' circuit side only.
   / plow on a 1320
That is similar to what I did except that I took the bucket off and built a quick attach to the end of the lift arms with a cable running back to the loader arms to keep the plow from rolling forward when it is lifted. I will try to just move the lever a little bit to see if that works. Maybe I was just a little too "enthusiastic." Thanks
Tradewinds Power Unit (A50120)
Tradewinds Power...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
22ft T/A Enclosed Cargo Trailer (A51694)
22ft T/A Enclosed...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2018 Dodge Charger Sedan (A51694)
2018 Dodge Charger...
2019 KENWORTH T880 (A52472)
2019 KENWORTH T880...
