plow on a 1320
   / plow on a 1320 #1
firstblue
I put an all angle plow on my 89 ford 1320. I tried using the bucket curl hydraulics to angle the plow, but plow would only angle to the left and not swing back to the right. I attached directly to the quick connects for the loader. The plow has two single acting cylinders instead of the double acting for the bucket - would this make a differnence? Any ideas?
   / plow on a 1320 #2
Welcome to the forum.
I believe I have the same setup for plow as yours, i.e. Western plow with three one-way rams.
If I throw the 'curl' lever far to the right (brings the quick dump feature into play) then my snowplow will not angle to the right. However, if I just move the lever to the first 'curl dump' position, then the regenerative circuit doesn't come into play and the blade angles perfectly, same as to the left.
I hook up the angle cylinders to the bucket and the one-way ram to the 'lift' circuit side only.
   / plow on a 1320
That is similar to what I did except that I took the bucket off and built a quick attach to the end of the lift arms with a cable running back to the loader arms to keep the plow from rolling forward when it is lifted. I will try to just move the lever a little bit to see if that works. Maybe I was just a little too "enthusiastic." Thanks
2012 International 4300 Reefer Truck (A52748)
2012 International...
378801 (A51572)
378801 (A51572)
2010 CHEVROLET SILVERADO 3500 (A52472)
2010 CHEVROLET...
2018 VOLVO VNL DAY CAB (A52576)
2018 VOLVO VNL DAY...
2016 LT63 Towable Light Tower (A51691)
2016 LT63 Towable...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
