Plow help
/ Plow help #21
CW and CCW have different meanings depending on which side of the plow he is looking at.
/ Plow help #22
I cut the pins off because the were to small so I welded the size I needed. That might have something to do with it!!! When I cut them off I left a little bit so A could put the pins in the center.
Where the pins to short or was the diameter too small? If the latter, then you can get bushings to adapt the pins to a bigger hitch.
213130 (A64276)
213130 (A64276)
1986 Ford LN8000 Fertilizer Truck, CAT 3406 Engine, Ag-Ready Workhorse (A63689)
1986 Ford LN8000...
2012 Infiniti G37 Sport (A62613)
2012 Infiniti G37...
2022 EZ-GO ELITE...
2007 Mack CV713 Granite T/A Pole Truck (A62679)
2007 Mack CV713...
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
