plow for Kubota
   / plow for Kubota #11
Should be no problem. I previously had a Yanmar 240 (24 hp) with a single bottom plow (before the B2100 I have now with a tiller). Even with turfs and 2wd it would turn over any ground I attempted to work. Take your time and experiment, that is the fun of this work.
   / plow for Kubota #12
dacus; I have a L2350 that pulls a 12" two bottom. Has no problem at all. My ground has alot of clay in it. First time I plowed it with sod on it. I plowed in low range high gear. Now I can plow in high range second gear. I think you will be ok just take your time and have fun./w3tcompact/icons/smile.gif/w3tcompact/icons/smile.gif
I do have ags,and there not filled.
Camshaft in Pa.
   / plow for Kubota #13
I have done some more experimenting with my 7500DT and 12" FarmStar plow. I set the depth stop on the three point to take the guess work out of it. It took some trial and error but I got a good compromise on depth, and was able to plow without near as many hangups. My ground has a considerable amount of clay which is most of the problem. I plow as fast as the tractor can so it throws the sod over better. When I had my old Massey 50 and two bottom I had a lot of trouble with sod flipping back over. But this little plow from TSC does a heck of a job on my bota when it isn't hanging the tractor. I should mention that hanging the tractor mostly occurs when breaking new ground. If I'm plowing ground that was worked the previous year I can cook right along. I still want a tiller, but I think now I'll keep my plow even if/when I get the tiller. Oh one more thing... the old Massey (MF-50) would get hung some too.
   / plow for Kubota #14
A plow for breaking sod has a different moleboard [ it will turn the sod over ] than one used on previously tilled land.
Egon
Quick Attach Bale Spear (A57454)
Quick Attach Bale...
2014 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A58214)
2014 HEIL TRAILER...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
SKID STEER ATTACHMENT ROCK SIFTER WITH BUCKET (A58214)
SKID STEER...
78in Dual Cylinder Brush Grapple Skid Steer Attachment (A56857)
78in Dual Cylinder...
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
