Please recommend FEL for NH 7610 S
   / Please recommend FEL for NH 7610 S #1
pharmvet
Platinum Member
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
I recently agreed to purchase a 2001 NH 7610S mfwa. It does not have a FEL. What brand / model would you recommend. I will be using the FEL mostly for brush and general wildlife habitat mgt. I will not be feeding hay or loading grain etc. I am also considering a grapple. I would like your advice and recommendations. thanks
   / Please recommend FEL for NH 7610 S #2
Contact Westendorf. I have always heard good things about their loaders. Also you can look at Quike/Alo as they are high quality loaders as well and will work well for you.
I like the looks of the Quicke brand loaders. I have heard good thing about them as well. What specific model would you recommend for a 4wd 7610S? I want to do some research and see if I can find a slightly used one. Also, what, if anything, extra is necessary to operate a grapple?
Finally, will a loader come with a joystick and can the hydraulics be plummed into the tractor so that the remotes are not used?
thanks
   / Please recommend FEL for NH 7610 S #4
thanks
I don't know which specific model but I am sure a quick call to a dealer will get you an answer. I am not positive on everything needed to run a grapple and am not confident enough with what I do know to give you advice on it. Others on here will be able to explain it in detail though. I know Westendorf has a grapple that doesn't require anything extra but it isn't a conventional grapple but would be great for handling logs and brush.
The joystick would be an option you buy with the loader as not every aftermarket loader would need one as some tractors already have joysticks on them. You would need to plumb it into the tractor and the joystick should come with what you need to do that as a kit.
   / Please recommend FEL for NH 7610 S #5
I bought an EZee-On for my 4610 and installed it myself.
Kobelco MD 200B LC Excavator (A52384)
Kobelco MD 200B LC...
2008 Saturn VUE XE SUV (A53117)
2008 Saturn VUE XE...
Deere 331G (A50123)
Deere 331G (A50123)
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A53473)
Texas Post Driver...
2017 Freightliner M2 106 T/A 4,000 Gallon Water Truck (A51692)
2017 Freightliner...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A53473)
NEW 2024 LOAD...
