Please recommend FEL for NH 7610 S
   / Please recommend FEL for NH 7610 S #1
pharmvet
Platinum Member
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
I recently agreed to purchase a 2001 NH 7610S mfwa. It does not have a FEL. What brand / model would you recommend. I will be using the FEL mostly for brush and general wildlife habitat mgt. I will not be feeding hay or loading grain etc. I am also considering a grapple. I would like your advice and recommendations. thanks
   / Please recommend FEL for NH 7610 S #2
Contact Westendorf. I have always heard good things about their loaders. Also you can look at Quike/Alo as they are high quality loaders as well and will work well for you.
I like the looks of the Quicke brand loaders. I have heard good thing about them as well. What specific model would you recommend for a 4wd 7610S? I want to do some research and see if I can find a slightly used one. Also, what, if anything, extra is necessary to operate a grapple?
Finally, will a loader come with a joystick and can the hydraulics be plummed into the tractor so that the remotes are not used?
thanks
   / Please recommend FEL for NH 7610 S #4
thanks
I don't know which specific model but I am sure a quick call to a dealer will get you an answer. I am not positive on everything needed to run a grapple and am not confident enough with what I do know to give you advice on it. Others on here will be able to explain it in detail though. I know Westendorf has a grapple that doesn't require anything extra but it isn't a conventional grapple but would be great for handling logs and brush.
The joystick would be an option you buy with the loader as not every aftermarket loader would need one as some tractors already have joysticks on them. You would need to plumb it into the tractor and the joystick should come with what you need to do that as a kit.
   / Please recommend FEL for NH 7610 S #5
I bought an EZee-On for my 4610 and installed it myself.
2012 Chevrolet Equinox 1LT SUV (A51694)
2012 Chevrolet...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53473)
2012 JOHN DEERE...
GOODYEAR SET OF 9.5-24 AG TIRES (NEW) (A53473)
GOODYEAR SET OF...
2012 Ford Crown Victoria Sedan (A51694)
2012 Ford Crown...
