Tiller Please provide info on this tiller
   / Please provide info on this tiller #1
kpbeddin
NW South Carolina
Kubota BX 2200 and LS I3030
Can someone provide some information as to the model of this Bush hog tiller? I can buy it for $800.00 but don't know enough about it to determine if it is good deal or not. The owner says it is about 5 years old. Thanks in advance.
   / Please provide info on this tiller #2
What size is it? Looks to be about 40" (give or take) long.
Any model number showing?
If in near perfect condition, $800 seems fair.
It is advertised as a 42 in. and I did not get the model number (I intend to go back and try to get a model number). It is not in perfect condition, the rear shield is bent a little, but the tines appear to be in good shape.
   / Please provide info on this tiller #4
Rear shields bend easy. If the tines are good then means not many hours. What size tractor do you intend to use it behind?
   / Please provide info on this tiller #5
Turn the PTO shaft and make sure the tine shaft turns with it. Should move smoothly.
I plan to use it with a BX 2200. It has been used with a Ford 1100 (13 HP). Hopefully I will get a chance to do some more looking today, Thanks for the advice about turning the shaft, I will try that also.
   / Please provide info on this tiller #7
It looks like there is still plenty of paint on the tines and they don't appear to be warn in that tiny picture. In my neighborhood an $800 tiller in that good shape would sell in 15 seconds or less.
   / Please provide info on this tiller #8
Rear shield no big deal, as others have said try and see it working on tractor or if you can turn shaft by hand. Tines you said look OK
I have a 48" and have had no complaint what so ever !!!!
Us it 6 or 7 times a yr or more tilling 3 different gardens.
Good luck
John Deere 1025R Sub-Compact Tractor Mower (A56857)
John Deere 1025R...
1969 Lincoln Continental Mark III (A56859)
1969 Lincoln...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
1995 Rinker Captiva 190 (A56435)
1995 Rinker...
excavator trenching bucket- one bucket per lot (A56435)
excavator...
