Please Help
   / Please Help #1
tucke022
Branson 2400
I have a branson 2400 with back hoe. The tractor has 3 hydraulic hoses that hook to the back hoe. I traced one out and it goes to the pb port on the fel valve. The other two I assume go to the tank. I purchased a 3 pt log splitter from tsc and I have it plumbed but when i lift the rear 3 point arms up the ram moves on the log splitter. I called the log splitter company and they said i have to have a feed from my main line and i cannot come off the pb port on the fel valve but my backhoe works fine off this? Anybody have any ideas? The tractor has a open valve system.
   / Please Help
When I raise my 3 point arms with the splitter attached the ram starts to move at the same time the arms go up. Then when the arms stop moving the the ram keeps moving?
   / Please Help #4
Do you have a log splitter valve on the log splitter?
The hose from the FEL PB, with a QD on it , call it BH1, should feed the IN port of the log splitter valve. the hose from the 3pt to the rear QD, call it BH2. A hose from BH2 QD should go to the OUT port on the log splitter valve. That completes the hyd circuit. The third hose from the BH is the OUT hose on the BH valve to tank, and is only used when using the BH. .
If nothing is being used on the rear, then a short jumper hose should connect the two BH1, BH2 rear QD's together. .
You should have about 7.7 GPM's.
   / Please Help
Also the log splitter works great but its just that weird problem I am having and worried something might not be connected right.
   / Please Help #7
No matter how you hook up the log splitter, the fluid should just flow through the valve until you push a lever, or put it into detent.
With the log splitter attached, when you raise the 3t, you are pressurizing the complete hyd circuit from the pump to the 3pt. . The only way for the log splitter cyl to extend is for the back pressure to flow past the valve spools.
If you installed a 3000 hyd pressure gage, you could check out the hyd system.
Flow path = pump, PB out, log splitter in, log splitter out to 3pt in, then tank.
The OUT hose stays with the BH, and is only used when using the BH. It sends all the cyl fluid to tank.
   / Please Help
Do you now where the best price gauges are?
   / Please Help #9
At least 3000 psi gage, preferable liquid filled.
Surplus Center
Try also Northern Tools.
First gage plugs into a matching QD, and the other plugs in wherever.
   / Please Help
I spoke again with my tractor dealer and told him the problem and he told me that the pyb from the loader valve feeds the 3 point arms as well and I can't lift the arms with the splitter attached or I will mess my pump up. Any body else have to do this?
1-Pallet Brake Chambers (A53117)
1-Pallet Brake...
2017 Takeuchi TL8 (A47477)
2017 Takeuchi TL8...
(10) 20 in. X 2 ft. Insulated Garage Doors (A53117)
(10) 20 in. X 2...
2018 TY-CROP MANUFACTURING LTD DRY BULK PNEUMATIC TRAILER (A53843)
2018 TY-CROP...
2014 FORD F-350 (A53422)
2014 FORD F-350...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52705)
KNOW BEFORE YOU...
