please help
/ please help #1
mralabama98
john deere la110
i have a john deere la110 and when i engage the blades the engine shuts off
/ please help #2
Are you engaging the blades at full throttle, half throttle, or idle? Does that unit use an electric clutch or a manual one? electric clutches use a pull up knob, while manual ones use a lever. Is your deck clean of caked on grass, etc?
BTW, Welcome.
/ please help #3
Could be a safety switch, my mothers craftsman the engine will stop running if you engage the mower and you are not sitting on the seat. I check the switches on your seat.:D
/ please help #5
Do you have it in reverse?
/ please help #6
If you hear belt squeal then stall it is likely seized spindle or blade brake
If she just shuts down like you are shutting off the key then it is a safety switch
Make sure you are in neutral and seated
Joel
RoGator RG1300C (A63688)
RoGator RG1300C...
(INOP) JOHN DEERE 694 CORN HEAD (A63291)
(INOP) JOHN DEERE...
2005 Ford F-150 Ext Cab Pickup Truck (A61573)
2005 Ford F-150...
2025 SF60 60in Hydraulic Side Shift Forks Skid Steer Attachment (A61572)
2025 SF60 60in...
207269 (A52708)
207269 (A52708)
2021 PETERBILT 367 (A63569)
2021 PETERBILT 367...
