please help
/ please help #1
mralabama98
john deere la110
i have a john deere la110 and when i engage the blades the engine shuts off
/ please help #2
Are you engaging the blades at full throttle, half throttle, or idle? Does that unit use an electric clutch or a manual one? electric clutches use a pull up knob, while manual ones use a lever. Is your deck clean of caked on grass, etc?
BTW, Welcome.
/ please help #3
Could be a safety switch, my mothers craftsman the engine will stop running if you engage the mower and you are not sitting on the seat. I check the switches on your seat.:D
/ please help #5
Do you have it in reverse?
/ please help #6
If you hear belt squeal then stall it is likely seized spindle or blade brake
If she just shuts down like you are shutting off the key then it is a safety switch
Make sure you are in neutral and seated
Joel
2022 EZ-GO ELITE...
2015 KENWORTH T800 HYDROVAC (A63569)
2015 KENWORTH T800...
2001 Freightliner FLD120 T/A Sleeper Cab Truck Tractor (A61573)
2001 Freightliner...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
ALUMINUM HEAD ACHE RACK (A63569)
ALUMINUM HEAD ACHE...
2012 MACK CHU (PINNACLE) (A63569)
2012 MACK CHU...
