please help, problem with electric pto
   / please help, problem with electric pto #1
Hellsnightmare
Sangerville, Maine
husqvarna
Its around 6 or 7 years old at least, not sure the model im not near it but its a 24hrsp. But the pto will work on and off, if you step on the hydro forward ot engauges but if you let off or go on reveres it will stop or hit bumps. I cant find a chaffed wire or loose plug. But its acting like a bad ground but i dont see any loose wires. Please help
   / please help, problem with electric pto #2
Not famalier with that model but just wanted to share with you. I have a John Deere GT 235 HYDRO and when you mow in reverse you have to "hold up" pto button/switch for a couple seconds before or it will de-activate pto attempting to mow in reverse. Just a thought.
Boone
   / please help, problem with electric pto #3
Is this a new problem that recently developed?
   / please help, problem with electric pto #4
What make is it?
   / please help, problem with electric pto #5
could be the seat switch. Also, my Husk lawnmower will not mow in reverse unless you switch the key one step to the left....very odd.
The seat switch will kill it if its not activating properly...but i would think it would also kill the motor....not sure on that.
Otherwise i would suspect loose wire somewheres.
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
CAT 973 (A47384)
CAT 973 (A47384)
STORAGE FEES (A54607)
ROLOFF 500 BBL FRAC TANK (A53843)
ROLOFF 500 BBL...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
