Please help me get my tractor started
/ Please help me get my tractor started #21
I"m guessing the neighbor with the VOM checked for voltage on the coil side of the relay, if not the relay is not yet condemned. I had a glow plug relay out on one that drove me nuts for over half an hour. YOu could turn on the glow plugs, get no voltage on the buss bar. but unplug the bus bar from the relay and have 12 volts. The contacts were allowing voltage to pass, but no amperage, with any load, the voltage was dropping to almost zero. Replacing the relay solved the problem.
it was the relay...popped the new one in and viola...or i mean varoom.
thanks again for the quick suggestions and encouragment.
/ Please help me get my tractor started #23
Just had my relay poop the bed last week, changed it out and it works fine. Mine was the opposite tho, it wouldnt shut off when I turned the key. all better now
/ Please help me get my tractor started #24
Would all of this apply to a CK20 as well? Went to start my tractor saturday and all I got was this slight clicking sound, glow plug light came on and went off like the glow plugs were cycling. Checked battery voltage and have 12.6 volts across the terminals as well as from the point were the the ground bolts to the frame to the pos side. If this relay is the problem where would a feller find it?
/ Please help me get my tractor started #25
unhappy, Put the Battery on a charger for a few hours. In my experience just because the voltage tests "ok" doesn't mean the battery has the amperage to turn the starter over.
/ Please help me get my tractor started #26
Yup, have to agree w/Toad. If the solenoid is clicking but the starter not engaging the flywheel with enough juice(amperage) to spin over the motor, give your battery a boost. I'd also check the battery connections, re-tighten/clean as necessary. My Negative was slightly loose, but still connected and my results sounded just like yours, glow plugs, all other indiot lights on and starter just clicking. Not enough juice, retightened connection good to go. A weak battery would do the same thing.
Good luck.
2021 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2021 ASV RT-25...
2016 Hyundia 53' Dry Van Trailer (A62613)
2016 Hyundia 53'...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2012 VOLVO SD105DX SMOOTH DRUM ROLLER (A64279)
2012 VOLVO SD105DX...
2017 Jeep Patriot 4x4 SUV (A61574)
2017 Jeep Patriot...
2012 John Deere 6430 102HP Agricultural 4WD Tractor (A61572)
2012 John Deere...
